forged pistons
blown473
DanH
motorhead
forged pistons
I would like to know the pros and cons on using forged pistons in a 460 that will be a daily driver on the wild side?
motorhead- Posts : 75
Re: forged pistons
one con would be that they would be driven on the Wild Side , and get a new friend with lights on his car
the pro the will hold up better than a cast .
DanH- Posts : 1081
pistons.
No real downside at all, flat out better pistons.
blown473- Posts : 376
Re: forged pistons
blown473 wrote:No real downside at all, flat out better pistons.
They are barely more audible when cold ... that's about the only con.
forged pistons
Well I don't need the lighted car friends, but I am thinking about using the forged but I only need to stay around 10:5 .1 for pump gas.
Re: forged pistons
definetly go with forged pistons, they are typicaly much higher quality than the cast stuff and much much more durable when engaged in the "Wild Side"
forged pistons
What would be the best brand for of forged that would not be to expensive?
Re: forged pistons
there is no doubt that a forge piston is stronger but if u r running n/a on the streets hyper will live easy and perform well in a 10.5 to 1 motor
quick 52- Posts : 612
Re: forged pistons
The downside to the forged pistons is up front cost. They are very durable though and will give a long service life. If you decide to run the hyper pistons, keep the rpms reasonable, they don't like a lot of piston speed much like a cast piston. The forged pistons can be a little more forgiving if you experience detonation too. I broke a hyper piston from detonation one time.
schmitty- Posts : 4538
Re: forged pistons
Depends on how much you want to spend and what features you need..... Like Lem has said, probe makes some great stuff for BBF's in the entry and mid levels.
Once you start wanting different options and configurations you start getting into higher end stuff like JE, Diamond, BRC, Arias, Ross, ect.
» sbf forged pistons
» trw pistons
» 429 forged pistons
» FORGED TRW PISTONS
» WTB forged STD bore 429 pistons
» trw pistons
