lobe seperation angle
Can someone give me a detailed description of lobe seperation angle?
motorhead- Posts : 75
Re: lobe seperation angle
motorhead wrote:Can someone give me a detailed description of lobe seperation angle?
Not much detail ... it is all geometrical. It is the distance in camshaft degrees between the center of the intake lobe and the center of the exhaust lobe pertaining to the same cylinder.
degrees closest to 108 means the cam will have lots of overlap and operate at a higher rpm and less bottom end, degrees closest to 114 means more bottom end, mild idle (more suited to a tow truck)
cooter- Posts : 220
cooter wrote:degrees closest to 108 means the cam will have lots of overlap and operate at a higher rpm and less bottom end, degrees closest to 114 means more bottom end, mild idle (more suited to a tow truck)
Don't try to over simplify the reasoning ... in that case WHY do Pro-Stock engines have lobe separations of 116 to 118 ...?
Rm, you write "not much detail" and i am over simplifying? Pro stock engines have there own set of guidelines. Add to the conversation if you have something to add, i fail to recognize how your last post helped motorhead to understand lobe seperation. I understand you are experienced but why not stick to info useful to 90 percent of engines? Not trying to be an ass but it drives me nuts that some people want to throw a curve to everything. Why not tell us why a 100 thousand dollar prostock motor defies the principles of lobe seperation so we can all learn something?
cooter- Posts : 220
The amount of overlap a camshaft has is not a function of LSA by itself. In fact it's entirely possible for a cam with an LSA of 112 to have more overlap than a cam with an LSA of 108. Duration also comes into play.cooter wrote:degrees closest to 108 means the cam will have lots of overlap and operate at a higher rpm and less bottom end, degrees closest to 114 means more bottom end, mild idle (more suited to a tow truck)
Paul
If only the lsa changes between 2 camshafts, is there a situation where the 112 lsa cam would have more overlap?
cooter- Posts : 220
cooter wrote:If only the lsa changes between 2 camshafts, is there a situation where the 112 lsa cam would have more overlap?
If you're talking about two identical camshafts save the LSA.. yes - going from a 114 to a 112
The OP asked for a "detailed description" of LSA.. Randy gave him a 100% correct answer, you gave an answer that applies to some engines under some circumstances of what LSA contributes to, as Paul alluded.
No one is "throwing curves".. the experts responded with fact.
You guys are correct and i apolagize for my post. My shitty morning caused me to throw my own curve here. Please except my retraction, i love this site and to learn from everyone on here.
cooter- Posts : 220
As I read the original question, it only asks what lobe separation IS and nothing to do with any "cause & affect" of what it may or may not do.
Whatever curve certainly didn't originate from here.
When the post said DETAILED, i assumed he was looking for more info to aid in the understanding of LSA. I did apolagize and retract and even sent a pm to you randy which i hope you except. I would however love to discuss LSA in a new post if anyone is up for it.
cooter- Posts : 220
» Lobe seperation - Manual vs Automatic
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» Drive Shaft angle vs Pinion angle
» 562 possible cam swap
» cam lobe vs. lifter centerline
