Part #'S
manofmerc
tconnection
Part #'S
Wanting to know the part #'s for the best rear main seal and pan gasket for moroso pan.
Thanks for any info.
tconnection- Posts : 866
Pan gasket and seal
I have had sucess with the fel pro rear main seal myself .And this last fall when I did a freshen up on my 460 I went with the one piece oil pan gasket .That was the best pan gasket I have ever used on a 460 .I purchased the ford motorsports version .Why dont you contact mr.Lem Evans he probably has what you need .Where do you race at in Ga. ? I live in Ga. also .Doug
manofmerc- BBF CONTRIBUTOR
Re: Part #'S
as far as pan gaskets, either the one piece as suggested above or TA-31........
Re: Part #'S
One piece FRPP pan gasket and a FRPP rear seal. Can't go wrong with either...
jbozzelle- Posts : 3705
Re: Part #'S
surrounding me is Douglas Ga, Adel Ga, Albany Ga, and Twiggs Co.
Where are you located? Thanks for all the info,men.
Re: Part #'S
Most of the rear main seals are made a little sloppy these days ... the rubber is allowed to run past the wire insert on the ends and shouldn't in most cases. Removing a few thou off the ends is usually necessary.
I am in Griffin Ga.
I go to silver dollar raceway in reynolds .I have a white 67 comet .What is your ride ? Get that one piece pan gasket you will love it.Doug
Re: Part #'S
jbozzelle wrote:One piece FRPP pan gasket and a FRPP rear seal. Can't go wrong with either...
The FRPP rear main I got is a FEL-Pro deal
Ace
powerstrokeace- Posts : 1496
