AR52's need to be smaller?
AR52's need to be smaller? Empty AR52's need to be smaller?
Post  powerstrokeace April 7th 2012, 5:12 pm
Guys I've been finishing up the current motor and put in exhaust studs and now I can't get a spark plug socket on to tighten it up. Is there and thing that has the smaller 5/8 hex plug? Current spark plug is an AR52 autolite
Ace
powerstrokeace
powerstrokeace
AR52's need to be smaller? Empty Re: AR52's need to be smaller?
Post  Lem Evans April 7th 2012, 5:52 pm
AR3934 may be a place to start.
Post  powerstrokeace April 7th 2012, 8:38 pm
how much different are they from the 52's
Ace
powerstrokeace
powerstrokeace
Post  powerstrokeace April 12th 2012, 12:23 am
Ok after some searching I have found out the 52's are a few steps hotter plug than the 3934. And I happen to come across the NGK r5671a-8 as the equivalent plug at the local motor cyles shop for $1.55. So I pick them up and will try these in the new motor Lem.
Looks like cold weather and rain this Sunday so no testing for me.
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans April 12th 2012, 9:46 am
Yes sir.........the NGK 8 will work too.
Post  powerstrokeace April 20th 2012, 2:08 pm
OK every things loaded up car has NGK plugs and we will be testing Saturday and Sunday. So Lem I'll let you know how things go as we will UNLEASH the motor and not run the throttle stop.
Ace
powerstrokeace
powerstrokeace
Post  cool40 April 20th 2012, 9:12 pm
i run the ngk-8 or the -9.works for me. Very Happy
Post  Lem Evans April 20th 2012, 10:24 pm
cool40 wrote:i run the ngk-8 or the -9.works for me. Very Happy
ngk 9 should work also.
Post  G-Code April 22nd 2012, 11:39 am
Lem Evans wrote:Yes sir.........the NGK 8 will work too.
Aren't those 2 stroke plugs....... ?
G Smile
Post  cool40 April 22nd 2012, 12:06 pm
champions are for chainsaws,ngk's for race cars. Razz
Post  hienergy557 April 22nd 2012, 10:19 pm
I use the NGK's in mine. Cheers Colin
hienergy557
hienergy557
