HEAD STUDS
HEAD STUDS Empty HEAD STUDS
Post  1970 ford maverick April 7th 2012, 7:26 pm
Can i use studs from dove-c heads on my new SCJ-6049 Heads?,rockers and head studs,THANKS,MAVMAN
1970 ford maverick
1970 ford maverick
HEAD STUDS Empty Re: HEAD STUDS
Post  c.evans April 8th 2012, 1:24 am
Most likely your rocker studs will be too short. The underhead length on a lot of older stuff was 1.750". Your SCJ heads need at least 1.900" underhead length for the rocker studs.
As for the head studs, the top row of studs will work okay. The bottom row needs to be a little bit taller on the SCJ heads, as compared to the DOVE-C heads. You can maybe make the bottom row work okay by just not screwing them into the block all the way. It's less than ideal, but...
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Gregaust April 8th 2012, 4:52 am
I found the normal length studs too short on the outer row on the heads . The Blue Thunder studs work sweet 255-4301 are 3/8" longer for 6.5" total where the stock length is 6-1/8"
Inners work fine and are same length
Gregaust
Post  1970 ford maverick April 8th 2012, 4:14 pm
c.evans wrote:Most likely your rocker studs will be too short. The underhead length on a lot of older stuff was 1.750". Your SCJ heads need at least 1.900" underhead length for the rocker studs.
Charlie Evans
THANKS ,MAVMAN
1970 ford maverick
1970 ford maverick
Post  1970 ford maverick April 8th 2012, 4:16 pm
Gregaust wrote:I found the normal length studs too short on the outer row on the heads . The Blue Thunder studs work sweet 255-4301 are 3/8" longer for 6.5" total where the stock length is 6-1/8"
THANKS,MAVMAN
1970 ford maverick
1970 ford maverick
