what gears?
Barney
what gears? Empty what gears?
Post  cool40 April 8th 2012, 10:28 pm
what rear gear do you big tire guys run? i'm think'n about a change! Laughing 2650# chassis car with 15x33 and a 1.80 glide.
what gears? Empty Re: what gears?
Post  richter69 April 8th 2012, 10:36 pm
4.29 here with a 100" rollout tire, I'd say a 4.88 deal would work w that tire in the 1/8th.
Post  Barney April 8th 2012, 10:37 pm
I have a 4.11 in there right now, thinking about changing it until I spray it real hard.
Barney
Barney
Post  David Cole April 8th 2012, 10:48 pm
cool40 wrote:what rear gear do you big tire guys run? i'm think'n about a change! Laughing 2650# chassis car with 15x33 and a 1.80 glide.
Run a 4.57 in mine, no way it could do a 4.88...converter is loose and it would trap too high in the 1/8
Post  cool40 April 8th 2012, 11:29 pm
thats where i'm at,4.56. my 60' improved with the sissy bars and now i'm back where i was with 4.86,shift light is on too long on the far end. shift @6800 and cross about 7200 but it's real done at 7200,i mean on 7200 about last 75-100ft. last year the 4.86 to 4.56 did'nt do much,maybe 200rpm less on the far end and no real 60'loss.i thought i was leaving @4800 friday nigh but i was @4200,the last years m5 pass made me drop it to keep the frontend down.it's 60'n hard enough i think it'll pull less gear,what yall think? 4.30-4.11?
Post  Barney April 8th 2012, 11:43 pm
I'm thinking about changing to a 4.30. The 4.11 will be ok for the quarter which is what I run 99 percent of the time. I may change it for the June race but I doubt it. I'm pretty much gonna be in test mode for the June race so I may leave it to see where I am. Not knowing car that well its hard to make a recommendation. If your 60 is the same with the taller gear I can't see where it would hurt to throw some in and give it a shot.
Barney
Barney
Post  dfree383 April 9th 2012, 12:09 am
4.30 hear..... Looking at upping that to a 4.56 or 4.86 for this small motor.
Post  cool40 April 9th 2012, 12:11 am
Barney wrote:I'm thinking about changing to a 4.30. The 4.11 will be ok for the quarter which is what I run 99 percent of the time. I may change it for the June race but I doubt it. I'm pretty much gonna be in test mode for the June race so I may leave it to see where I am. Not knowing car that well its hard to make a recommendation. If your 60 is the same with the taller gear I can't see where it would hurt to throw some in and give it a shot.
as i've tuned on it the 60' has came down but mph has not went up,it's just done @7200 with track left.i've noticed some talk of 1.69 low gear glides and some cars kinda like mine run 3.90 gears Shocked i may be where i need to be but it just feals like it's never loaded,even off the line.
Post  cool40 April 9th 2012, 12:12 am
dfree383 wrote:4.30 hear..... Looking at upping that to a 4.56 or 4.86 for this small motor.
how small?
Post  dfree383 April 9th 2012, 12:20 am
466....... Baby Engine.
I have a 3.89 gear in the case I'm going to use for the 4.56 or 4.86.
Post  cool40 April 9th 2012, 12:29 am
dfree383 wrote:466....... Baby Engine.
i dont think that'd work for me,lol.4.10 may kill it but i'm sure 4.30 would'nt hurt it.
Post  cool40 April 9th 2012, 12:42 am
maybe this will work, put it on a yard dart in tnt,lol. you can hear it good anyway,also my little red head crew member. Laughing https://www.youtube.com/watch?v=2crrZlY2Ucg&feature=g-upl&context=G2833a34AUAAAAAAABAA
Post  dfree383 April 9th 2012, 1:08 am
Go Daddy Go !! Go Daddy Go !!! cheers
Post  BigDave65 April 9th 2012, 11:46 am
5.14 in mine. 16x33's, 1.80 glide. Probably going to go to a 4.88 next time around. In 1/8th mile racing you don't see a lot of rpm change on top end by changing ratios. Usually has more of an affect on launch and 60's.
BigDave65
BigDave65
Post  cool40 April 9th 2012, 1:53 pm
BigDave65 wrote:5.14 in mine. 16x33's, 1.80 glide. Probably going to go to a 4.88 next time around. In 1/8th mile racing you don't see a lot of rpm change on top end by changing ratios. Usually has more of an affect on launch and 60's.
affraid you turn it up dont you! wish i had a belt drive on the motor,i'd back the cam up.it makes real good power but when its done its done. Laughing
Post  BigDave65 April 10th 2012, 12:28 am
Shift at 7k, go through lights at 71-72. Convertor flashes about 5800 on the transbrake.
BigDave65
BigDave65
Post  valleydawg April 10th 2012, 1:20 pm
4.10 in mine.
valleydawg
valleydawg
Post  cool40 April 10th 2012, 1:40 pm
valleydawg wrote:4.10 in mine.
i know your fast Cool cid? any spray?
Post  valleydawg April 10th 2012, 1:57 pm
598 with two systems shifting at 7.
valleydawg
valleydawg
Post  cool40 April 10th 2012, 2:00 pm
valleydawg wrote:598 with two systems shifting at 7.
wow,that'll pull a 4.10 gear!
Post  cool40 July 3rd 2014, 11:33 pm
Bring this back from the dead! Anyone go a different way with gears lately? Last time i needed to get rpm under control but this motor wants to rpm.my gear now is 4.30 tire is 106.5 rollout. The converter works very good now after the 3rd try.im shifting @ 2.6into the run at 7600rpm which imo is way to far out in low gear.when I shift it drops 800rpm and only has time to pull back up to cross at 7000rpm @135mph. I'm thinking a gear change...4.86 maybe! Idea
