Good source for rebuild kit
Good source for rebuild kit Empty Good source for rebuild kit
Post  67MercCat April 11th 2012, 8:07 pm
Hey I'm looking for a good complete rebuild kit for my 429 (1970 block) and I found a few but I don't know if they're any good. I'm not looking for anything spectacular, I just want to build the engine back to it's original condition for now. Any suggestions?
Also how can I tell if I need undersized bearings? (STD, .010 .020 .030) I'm really new to this so I'm going at a snail pace.
Thanks fellas
67MercCat
Good source for rebuild kit Empty Re: Good source for rebuild kit
Post  69F100 April 11th 2012, 8:47 pm
the bearing size should be stamped on the backside of the bearings on a rebuild kit any good brand names I would leave the off the wall brands alone
Post  cletus66 April 11th 2012, 8:59 pm
A couple of years ago, I rebuilt my 302 with a "kit" from Adney Brown. If I remember correctly, it had rings, bearings, gaskets, oil pump, and timing chain. 140 bucks. Cool It won't really be a kit, tell him what you need and you'll get it.
Adney Brown –Performance Crankshaftinc
His signature describes his services pretty well, I think:
PERFORMANCE CRANKSHAFT INC,. YOUR FIRST STOP FOR CRANKSHAFT REPAIR , MODIFICATIONS AND CUSTOM CRANKSHAFTS /; ROTATING ASSEMBLIES ... coffee donuts and entertainment available at no extra charge ... shop phone 586-549-7557 lounge phone 313-873-6588
Good source for rebuild kit 81MustangRacecar351
The valve covers and air cleaner cost twice as much as the rebuild........ Embarassed
Post  67MercCat April 12th 2012, 12:18 am
wow all that for $140? thats fantastic. Do you have an email for him or is there a website I can visit for more info? The only brands I know are Clevite bearings but are there any others or are they simply the best?
67MercCat
Post  cooter April 12th 2012, 8:38 am
Check with your machine shop to see what they normally carry for parts. Acl, clevite, federal mogal all make good bearings. I like silvolite pistons for stock builds, fel pro gaskets. When the shop grinds the crank they will tell you what undersize you will need.
cooter
Post  rmcomprandy April 12th 2012, 9:38 am
cletus66 wrote:A couple of years ago, I rebuilt my 302 with a "kit" from Adney Brown. If I remember correctly, it had rings, bearings, gaskets, oil pump, and timing chain. 140 bucks. Cool It won't really be a kit, tell him what you need and you'll get it.
Bearings are a little more expensive for a big block than a 302 however, Adney WILL get you what you need.
Performance Crankshaft ...Adney; 1 (586)549-7557
