Spiro locks probe p2404f
Spiro locks probe p2404f Empty Spiro locks probe p2404f
Post  lobeeone April 19th 2012, 11:03 pm
Need a set of spiro locks for my pistons. Anyone know the part # or the actual size I need? Or have a set laying around?
lobeeone
Spiro locks probe p2404f Empty Re: Spiro locks probe p2404f
Post  bbf-falcon April 20th 2012, 8:07 am
Gotta know what the pin size is first. Then call your piston mfg. and they will either sell you some or tell you what you need. Lem probably carries them.
Post  lobeeone April 20th 2012, 9:57 am
Pin is 1.040" in diameter and 3.300" in length.
lobeeone
Post  Lem Evans April 20th 2012, 10:36 am
the locks I have are .990"......the best thing to do may be to contact Probe to make sure you get the correct parts. I've found the guys at Probe to be very helpfull.
Post  Mark O'Neal April 20th 2012, 1:25 pm
Smallet WHM-106 or Probe 14128
Mark O'Neal
Post  lobeeone April 20th 2012, 1:43 pm
Thanks guys , appreciate it
lobeeone
Post  lobeeone April 30th 2012, 10:14 pm
Ok guys who has the know how on installation of these dang spirolocks? They can't be that difficult...... Is there a tool??
lobeeone
Post  cool40 April 30th 2012, 10:26 pm
lobeeone wrote:Ok guys who has the know how on installation of these dang spirolocks? They can't be that difficult...... Is there a tool??
a small screwdriver with a little bend in it works for me,and fingernails. Laughing you gota start one end and twist it in.this is the easy part,get'n them out is a M*****$*****!
Post  lobeeone April 30th 2012, 10:57 pm
I'll try the small screwdriver with a bend. My bleeding fingers thank you..
lobeeone
Post  bbf-falcon May 1st 2012, 8:34 am
First thing I do is spread the spiral just enough to get the end started in the groove. Then i made me a pointed (screwdriver type) tool to keep shoving the lock in the groove while using the outside of the spiral to twist and turn it around the circumferance. After the first one it's not so bad. I never reuse them so removal is easy for mr,I just pry out the lip,grab the end w/needle nose plyers and twist it out.
Oh yea,oiling it helps a bunch too. Smile
