need bottom end torque specs
need bottom end torque specs Empty need bottom end torque specs
Post  429f150 May 14th 2012, 2:16 pm
Well i finally got everything rounded up now its time to start assembly. I need some torque specs for main bearing caps and oil pump bolts. Its a 1970 429 thunderjet any help is greatly appreciated.
429f150
need bottom end torque specs Empty Re: need bottom end torque specs
Post  IDT-572 May 14th 2012, 2:25 pm
105# on main caps it calls for 25 lb on the pump bolt, but I tighten them more than that.
Post  429f150 May 14th 2012, 3:09 pm
Thanks for the quick reply. What would you recommend for tq specs on the oil pump? I think 35 or 40 pounds should be plenty.
429f150
Post  61coon May 14th 2012, 7:42 pm
429f150 wrote:Thanks for the quick reply. What would you recommend for tq specs on the oil pump? I think 35 or 40 pounds should be plenty.
25-28 ft. Lbs. On the oil pump
61coon
61coon
