timing baselines for a 521 efi
timing baselines for a 521 efi Empty timing baselines for a 521 efi
Post  bottomland4x4 September 25th 2009, 7:14 pm
i am trying to adjust the timing on my efi521. i am wondering what the timing should be without the spout and with the spout. i am running 92 octane and around 10.5-1 comp. the engine is efi with a modified 5.0 a9L computer. it seems like if i set it at around 12 without out the spout and then it goes to 32 with the spout, and it runs like crap. if i set it around 16 -18 without the spout and then it goes to 39 with the spout, and runs a lot better, it really revs up quick. i have seen it go as high as 50 with the spout installed, while i was adjusting it.
what should be a good baseline? also i am setting the timing at idle around 1000rpm. should i set it at around 2000rpm idle? whats a good baseline? i know at 39 i can not hear any pinging or detonation. i am not really able to drive the car as much a i would like to. right now i found several exhaust leaks and also found out that one muffler is spaced about 18 inches farther back down the exhaust system than the other, i do not know why because there is nothin blocking it. i plan to install the mufflers about 16 inches behind the header flange and turn down after the muffler. it is all 3 inch with hooker aerochamber mufflers. maybe after the exhaust is straightened out it would be easier to hear any pinging.
any thoughts on this?
bottomland4x4
bottomland4x4
timing baselines for a 521 efi Empty Re: timing baselines for a 521 efi
Post  4thHorseman September 25th 2009, 9:45 pm
I'd say 12 to 16 initial, possibly a bit more if it has a big cam in it, and 36ish total in by 3000 when quick revving it should be a safe baseline. The efi computer will attempt to give it more timing at higher rpms for part throttle cruise condiditons. What I mean is, it is not uncommon to see timing well into the 40's while holding steady rpm at say 2600. But when you mat it, a proper tune should jump on your WOT programmed timing curve and advance to the 36ish you have for total. That was my experiebce tuning in a F.A.S.T. on my own previous ride and looking at others' tunes.
I currently also have a blown 4.6l in a 2008 stang. When I hook up my SCT tool it does exactly what I described. Kinda scary seeing 45 degrees at part throttle (0 boost) but that is how it is. Shocked
4thHorseman
4thHorseman
