92 oc or 110 octain gas
will a motor run cooler with the lower octain fuel or the 110 octain just a though i was wondering
cturk1010- Posts : 59
Re: 92 oc or 110 octain gas
cturk1010 wrote:will a motor run cooler with the lower octain fuel or the 110 octain just a though i was wondering
An engine will run the coolest with the CORRECT octane gasoline.
And correct tune and timing.
that is not the answer i was looking for someone was telling me that the higher octain would run a motor cooler than lower octain would even if the motor was tuned corectly
cturk1010 wrote:that is not the answer i was looking for someone was telling me that the higher octain would run a motor cooler than lower octain would even if the motor was tuned corectly
IMO No.
The Motor will make more power with the correct octane, you tend to loose power when you have to slow of burning fuel for the application.
