Fel-pro 1028
blown473
tconnection
Fel-pro 1028
About how much hp can they stand?
tconnection- Posts : 866
1028 fel pro head gasket
I can tell you they DONOT handle boost well, they failed at 12 psi.
blown473- Posts : 376
Re: Fel-pro 1028
Actually i got the ford racing's but they suppose to be basically the same.
A460 head 14:1cr and about 950hp n/a.
Re: Fel-pro 1028
I've run them in the past at 13-14:1, Better to get MLS stuff once you get above that or are spraying.
more on head gaskets
I now use the "ICS Titan" copper with embossing head gaskets. You don't have to O-ring, and they are indestructible. No water leaks common to plain copper like Milodon's. With these you can spray or boost as much as you want, or run very high Cr's .
Re: Fel-pro 1028
blown473 wrote:I now use the "ICS Titan" copper with embossing head gaskets. You don't have to O-ring, and they are indestructible. No water leaks common to plain copper like Milodon's. With these you can spray or boost as much as you want, or run very high Cr's .
Whats the thin-est they make.
res0rli9- BBF CONTRIBUTOR
Re: Fel-pro 1028
I'm not a big fan of copper in sportsman, long running stuff.
Re: Fel-pro 1028
res0rli9 wrote:Whats the thin-est they make.
Most "copper companies" will make ($) a gasket of your choosing.
Dave.
LivermoreDave- Posts : 972
Re: Fel-pro 1028
tconnection wrote:About how much hp can they stand?
I don't know their ceiling however, A customer is making almost 1,200 horsepower using 18 pounds of boost with a 12-71 supercharged, 528 inch drag boat engine.
more on gaskets
You can get pretty much any thickness & bore size from ICS Titan, and the cost is in the same range as the MLS gaskets.
Re: Fel-pro 1028
A friend a mine who builds a lot of bracket race engines ( mostly BBC) and runs the premium felpros at 15:1 in several engines with excellent results. I see no reason the bbf won't do fine at 14:1 with them assuming proper assembly and tune. I've personally run them at 13.5:1 with no problems on pulling trucks but I am no expert.
BradB- Posts : 43
Re: Fel-pro 1028
Thanks for all the info.
