BBF engine parts$$$
blown86hallet
tconnection
DNETT1727
powerstrokeace
stanggt
BBF engine parts$$$ Empty BBF engine parts$$$
Post  stanggt June 9th 2012, 5:33 pm
need to sell some BBF parts that I have been collecting for a 572 build.
Brand new this year from Lem, R-Series A460 TFS intake. I paid $642 to my door. $625 shipped
New Melling M84EHVS pump,no pickup, $50 shipped
MSD #8569 crank trigger dizzy NIB bought it a month ago. $215 shipped
good used timing cover, $35 shipped
double roller chain and gears. Top gear and chain new, reused the 3 keyway lower gear. very tight like a new one. $25 shipped
aluminum balancer with all the degrees stamped into it, its small in diameter and dont know who makes it but sell for $20 shipped
1/2 inch wood carb spacer like new with gaskets 4500 carb.$30 shipped
see below for info on the block If you need better pics,LMK and I will get them to u asap.
!!!!!UPDATED!!!!!!
Last edited by stanggt on June 18th 2012, 6:34 pm; edited 8 times in total (Reason for editing : added more info)
stanggt
stanggt
BBF engine parts$$$ Empty Re: BBF engine parts$$$
Post  powerstrokeace June 9th 2012, 5:42 pm
Pistons and rods?
powerstrokeace
powerstrokeace
Post  DNETT1727 June 9th 2012, 6:29 pm
so is the block for sale and what block is it
DNETT1727
DNETT1727
Post  stanggt June 9th 2012, 9:01 pm
powerstrokeace wrote:Pistons and rods?
the rods are childs&alberts nos and the pistons are BRC #4556 flat tops. they have spiral locks but not sure what pins were used. They were ran in an alky blown motor for 5 200ft passes and some break-in run time. They have new rings on them now as well as new bearings. they look like new yet, if u want some other pics LMK. Im thinkin $40 per hole so $320 for the set plus shipping.BBF engine parts$$$ Partstosell074BBF engine parts$$$ Partstosell073
stanggt
stanggt
Post  stanggt June 9th 2012, 9:09 pm
DNETT1727 wrote:so is the block for sale and what block is it
its a D1VE block with new arp studs, bronze freeze plugs, new hardblock to the bottom of waterpump holes, new cambearings and main bearings. some oilmods done and it is freshly bored to 4.5 inch with .170-.200 left in cylinders. $500 obo. its hard to sell to someone that cant come and ck it out themselves so hopfully someone close enough wants it so they can come ck it.BBF engine parts$$$ Partstosell045-1BBF engine parts$$$ Partstosell044-1
stanggt
stanggt
Post  tconnection June 10th 2012, 12:42 am
I'ld like to buy the valve covers if they clear a stud girdle on an ahead.
tconnection
Post  tconnection June 10th 2012, 1:14 am
will you post some pics of the valvecovers?
Pm me your address as well. Thank you. Would you happen to have a balancer bolt washer i can buy also. And a oil filter adaptor?
Thank you
tconnection
Post  stanggt June 10th 2012, 10:22 am
tconnection wrote:I'ld like to buy the valve covers if they clear a stud girdle on an ahead.
BBF engine parts$$$ Partstosell071
stanggt
stanggt
Post  blown86hallet June 10th 2012, 10:37 am
post a close up of the lifters..
If they in good condition I'd like to take them and the Valve covers.
Shipping will be to Belleville Mi...
blown86hallet
blown86hallet
Post  stanggt June 10th 2012, 7:21 pm
blown86hallet wrote:post a close up of the lifters..
BBF engine parts$$$ Partstosell080BBF engine parts$$$ Partstosell081about the best I can get with my camera.LMK
thanks,Chris
stanggt
stanggt
Post  stanggt June 10th 2012, 10:17 pm
sale pending on valve covers. Thanks
stanggt
stanggt
Post  fc2444 June 11th 2012, 3:11 pm
More info on rods and pistons
fc2444
http://amr-coatins.com
Post  stanggt June 11th 2012, 7:32 pm
fc2444 wrote:More info on rods and pistons
comp height is 1.350, 2.220 big ends,.990 pins?
stanggt
stanggt
Post  tconnection June 11th 2012, 11:27 pm
Payment shipped out today for valve covers.
tconnection
Post  69F100 June 11th 2012, 11:34 pm
pm sent
Post  fc2444 June 12th 2012, 9:05 am
What is rod lenght, piston bore, and what type of head is valve notches for?
fc2444
Post  stanggt June 12th 2012, 1:03 pm
fc2444 wrote:What is rod lenght, piston bore, and what type of head is valve notches for?
6.7 rod, 4.5 bore and they are either Aheads or stock location,still tryin to figure out for sure from BRC. Sorry bout that.
stanggt
stanggt
BBF engine parts$$$ Empty !!!LIST UPDATED!!!!
Post  stanggt June 13th 2012, 1:51 pm
updated list to what is left. Thanksguys
Chris
stanggt
stanggt
Post  stanggt June 16th 2012, 8:29 am
ttt bounce
stanggt
stanggt
Post  fc2444 June 16th 2012, 8:01 pm
Bore to big for me, have a dove-a block.
fc2444
BBF engine parts$$$ Empty updated list
Post  stanggt June 18th 2012, 6:35 pm
updated for what is left.
stanggt
stanggt
Post  hillbillyerv June 19th 2012, 10:25 am
are the rods n pistons still for sale ? need rods really dont need pistons to BIG fer me to. Shocked
hillbillyerv
hillbillyerv
Post  stanggt June 19th 2012, 2:06 pm
hillbillyerv wrote:are the rods n pistons still for sale ? need rods really dont need pistons to BIG fer me to. Shocked
sold the rods and pistons
sorry,thanks
chris
stanggt
stanggt
Post  Dave De June 20th 2012, 8:33 pm
I'll be in Midland July 4th thru the 7th. I may be interested in the block and the timing chain gear set.
Do you still have them?
Who did the work on the block?
Dave
Post  stanggt June 21st 2012, 11:21 pm
a shop over in West Branch. I can get the name and let u know and yes I still have them.
Chris
Dave De wrote:I'll be in Midland July 4th thru the 7th. I may be interested in the block and the timing chain gear set.
Dave
stanggt
stanggt
