Is crank trigger better than regular msd dizzy?
Is crank trigger better than regular msd dizzy? Empty Is crank trigger better than regular msd dizzy?
Post  deliveredfast September 27th 2009, 5:00 pm
Is crank trigger better than regular msd dizzy? If so why? what are the advantages or disadvantage of the crank trigger deal? thx.
deliveredfast
deliveredfast
Is crank trigger better than regular msd dizzy? Empty Re: Is crank trigger better than regular msd dizzy?
Post  72mav September 27th 2009, 7:36 pm
People tend to think CTs are more accurate since they are directly on the crank.
A convential Dizzy should be just as acurate if all the drives/etc are up to snuff.
Rick told me of a injected alcohol motor at the bash this summer and it had the good ole Duraspark on it. So I think speaks volumes for the dizzy. JMHO.
Al
72mav
72mav
Post  richter69 September 27th 2009, 7:38 pm
ct is more stable, i doubt you would see a diff in the two on a dyno.
Post  deliveredfast September 27th 2009, 10:15 pm
Ok thx guys.
deliveredfast
deliveredfast
Post  rmcomprandy September 27th 2009, 11:29 pm
Well, all you guys must be using some awfully low horsepower engines for your examples, as on dyno test after dyno test a crank trigger system has shown to NEVER produce less flywheel horsepower than a distributor triggered ignition system. Sometimes it is only a few and sometimes it is a lot but, it is never worse.
Post  BOSS 429 September 28th 2009, 12:24 am
crank trig's DO NOT PROMOTE SPARK jump(scatter) and less vib in the dist is always good,and are more dead on, no lash between cam,and dist gear
