parting out 68 galaxie
parting out 68 galaxie   Empty parting out 68 galaxie
Post  danev2 June 15th 2012, 1:06 am
1968 GALAXIE PARTS FOR SALE
PARTING OUT 1968 GALAXIE 500 LTD
ORIGINALLY 390/FMX 9 INCH BIG BEARING 31 SPLINE AXLE 3.00 OPEN
ENGINE/TRANS ALREADY GONE
FACTORY AIR CONDITIONING
ALL PARTS ON CAR FOR SALE
ALL PARTS IN VERY GOOD CONDITION , READY TO USE.
PHOTOBUCKET ALBUM OF ALL 68 GALAXIE PARTS AND PIECES
http://photobucket.com/68GALAXIE-FORDAUTOWRECKING
GALAXIE CAME FROM NEW MEXICO DESERT SO NO RUST OR CORROSION
390 428 FE ENGINE PERCHES. PAIR FROM 68 GALAXIE
FITS ALL FORD MERCURY FULL SIZE 65-68 AND PROBABLE SAME UP TO 71
PERFECT FOR CONVERSION TO SMALL BLOCK TO BIG BLOCK
$30.
DRIVER SIDE DOOR FROM 1968 GALAXIE
EXCELLENT CONDITION NO RUST NO DENTS. DOOR SHELL ONLY
NO WINDOWS OR HARDWARE.
OVERSIZE SHIPPING ON THIS ONE.
$50.
RIGHT SIDE PASSENGER OPTIONAL DOOR MIRROR. C7AB-17743-A
CAN ALSO BE USED ON LEFT DRIVER SIDE.
EXCELLENT CONDITION VERY GOOD CHROME AND GLASS.
CORRECT FOR 67-69
$20
65-68 GALAXIE LTD OUTSIDE DOOR HANDLES.
EXCELLENT CHROME AND NO SCRATCHES OR PITS.
BOTH WORK VERY WELL
$30 FOR PAIR
65-69 GALAXIE LTD OR MERCURY MONTEREY SUN VISORS.
EXCELLENT CONDITION ON VINYL
CHROME BASE AND STEM ON END HAS SOME PITS AND RUST SPOTS.
OVERALL STILL VERY NICE.
JUST NEED TO BUFF OUT OR RECHROME METAL TO MAKE PERFECT.
LIGHT TAN/GREEN “TAUPE?” COLOR.
LOOKS LIKE PUKE COLOR AFTER THE WEEKEND BENDER
$20
1968 FORD LINCOLN MERCURY
V8 AIR CLEANER HOUSING EXCELLENT CONDITION NO DENTS OR RUST.
FRESH PAINT FITS ALL FORD GALAXIE FALCON TORINO MUSTANG COUGAR FAIRLANE CYCLONE AND PICKUP TRUCK F100 F250 F350
FOR SMALL BLOCK 302 351W 351C 360 390 428 429 460 BIG BLOCK AND FE
$40
68 GALAXIE MERCURY FORD FULL SIZE SPLIT BENCH SEAT.
GOOD CONDITION BUT NEEDS RECOVERED.
SPRINGS AND FOAM ACTUALLY VERY GOOD AND NOT DRIED OUT OR RUSTED.
NO SPRINGS BROKEN
SPLIT BENCH WITH LATCH LOCKS ON SEAT BACKS NEW FOR 68
FITS PICKUP TRUCK AS WELL WITH TRUCK STYLE SEAT MOUNTS
FITS ALL BIG FORD BACK TO 65
LOCAL PICKUP ONLY UNLESS YOU WANT TO SPEND FREIGHT SHIPPING CHARGES.
$30
1965-68 GALAXIE MERCURY MONTEREY
2 SPEED WIPER MOTOR.
TESTED GOOD. BOLT IN FOR CONVERSION FROM SINGLE SPEED.
$25
68 GALAXIE FUEL FILLER NECK EXCELLENT CONDITION
SHOULD FIT FORD MERCURY FULL SIZE FROM 66 TO 68
$10
FORD AND CHRYSLER WHEEL SPACERS 1 INCH THICK
NOT A BOLT PATTERN CONVERSION PLATE.
5 ON 4 ½ FORD LINCOLN MERCURY
PLUS CHRYSLER MOPAR DODGE PLYMOUTH
VERY GOOD CONDITION NO DAMAGE AND BOLTS GOOD.
ALUMINUM
$20
68 GALAXIE GLOVE BOX HOUSING
BLACK PLASTIC.
VERY GOOD CONDITION
ALSO FIT MERCURY MONTEREY. PARK LANE,
$10
1965-68 GALAXIE MERCURY KICKPANELS
EXCELLENT CONDITION NO SPEAKER HOLES CUT IN OR CRACKS IN PLASTIC.
DARK GREEN BRONZE METALLIC COLOR.
HARD TO DESCRIBE DARK COLOR
HARD TO FIND THESE ANY MORE IN GOOD CONDITION
$30
FULL SET FRONT SEAT BELTS 68 FORD GALAXIE
BLACK COLOR AND IN EXCELLENT CONDITION
HAS ALL HARDWARE AND BOLTS.
RETRACTORS LEFT/RIGHT SIDE. SHOULDER BELTS AND SMALL CHROME CLIPS TO HOLD SHOULDER BELTS UP ALONG HEADLINER EDGE.
NO RUST AND NOT FRAYED
$30
FRONT BRAKE DRUMS
11 X 2 ¾ SIZE 2 3/8 INCH CENTER HUB DIA
FITS ALL 65-68
VERY GOOD CONDITION NO GROOVES AND STILL HAVE MATERIAL THICKNESS
EXPENSIVE TO BUY NEW AND NOT HIGH QUALITY IRON.
THESE ORIGINAL FOMOCO DRUMS LAST FOR DECADES.
STILL HAVE BEARING HUBS
$40 FOR PAIR.
KEYSTONE KLASSIC WHEEL 15X6 WITH FORD OR CHRYSLER BOLT PATTERN 5 ON 4 ½ 3 ½ INCH BACK SPACE.
NOT SLOTTED
EXCELLENT CONDITION NO DAMAGE TO RIM EDGES ONLY SLIGHT HINT OF CORROSION ON INSIDE EDGE OF RIM
ORGINAL KEYSTONE DATES BACK TO THE 60’S OR 70’S
HAD OLD GOODYEAR BIAS PLY TIRE MOUNTED
$40
HOOD HINGES $40
DRIVER SIDE WINDOW CRANK GEAR WORKS SMOOTHLY FITS 65-69 GALAXIE $40
DRIVER SIDE WING WINDOW CRANK GEAR
WORKS SMOOTH WITH LITTLE BACKLASH $30
GAS TANK STRAPS 66-69 GALAXIE, THUNDERBIRD, AND MECURY MONTEREY $20
SMOOTH NO SHIFTER STEERING COLUMN COMPETE EXCELLENT CONDITION
WITH TURN SIGNAL SWITCH AND INTEGRATED HAZARD FLASHER. WITH STEERING SHAFT. 68 UNIQUE COLAPSIBLE STYLE. FITS GALAXIE XL WITH FLOOR SHIFT. VERY RARE HARD TO FIND PIECE. MERCURY MONTEREY AS WELL. $80.
AUTOMATIC TRANS NEUTRAL SAFETY SWITCH COLUMN MOUNT STYLE
68-69 UNIQUE AND HAS ENGR DEV 842450#1 STAMPED ON IT.
TESTED GOOD. $20.
STEERING WHEEL HORN COVER PAD WITH LTD CREST ON IT.
VERY GOOD CONDITION. DARK COLOR NO CRACKS.
CAN BE USED ON MUSTANG COUGAR OR TORINO
JUST NEED TO REPLACE CENTER INSERT.
$25
EMAIL ME AT DANEV2 AT YAHOO COM
ALL PARTS SHIPPING FROM PHOENIX, AZ 85143
USPS OR UPS.
I CAN TAKE MORE DETAILED PICTURES OF PARTS AND EMAIL FOR SPECIFIC PARTS YOU MAY NEED.
EVERYTHING ON THE CAR IS FOR SALE.
PAYMENT BY CHECK OR MONEY ORDER, AND I WILL TAKE PAYPAL
FRONT CLIP COMPLETE FENDERS, INNER FENDERS, AND RADIATOR SUPPORT
GOOD NO RUST PIECES STRAIGHT SHEET METAL $300
CAN SELL INDIVIDUALLY. EACH FENDER $60 EACH
INNER FENDERS $60 EACH
RADIATOR SUPPORT $60.
ACCELERATOR CABLE FITS 65-69 GALAXIE LTD 7 LITRE ETC.
FOR BIG BLOCK FE 390 328 VERY GOOD CONDITION AND CABLE MOVES SMOOTHLY
$25
STEERING COLUMN SHIFTER BELL. FOR AUTOMATIC TRANS SHIFT ON COLUMN
PIVOT ON LEVER IS STILL NICE AND SNUG. NO SLOP
POINTER INTACT NO BROKEN. FITS 68-69 FORD MERCURY FULL SIZE
$20
ALUMINUM WHEEL ARCH RIGHT PASSENGER FRONT
VERY NICE CONDITION NO DENTS AND NO CORROSION
CAN’T HARDLY FIND THESE. NOT MADE AFTERMARKET
$40.
1968 GALAXIE 500 GRILL. GOOD CONDITION. NOT PERFECT. BUT LOOKS STRAIGHT AND VERTICAL AND HORIZONTAL BARS ARE GOOD AND INTACT.
NICE PIECE FOR A DRIVER CAR OR LOCAL SHOW CAR.
BOTH SIDES INCLUDED. $40.
68 GALAXIE ROCKER PANEL MOLDINGS GOOD CONDITION. NOT PERFECT BUT CANT HARDLY FIND THESE PIECES IN ANY SORT OF CONDITION ANYMORE.
GOT A FEW DENTS AND SCUFFS BUT NO HOLES DRILLED IN
NO HOLES ON SURFACE.
PAIR $50 SHIPPING OVERSIZE LENGTH.
I HAVE A FEW PARTS LISTED ON EBAY UNDER SELLER: FORDAUTOWRECKING
USPS OR UPS.
danev2
