Best Single 4 Cast Intake for A460 Heads
Barney
studly
anybody know? Nitrous application but large cubes 600 plus
studly- Posts : 512
Re: Best Single 4 Cast Intake for A460 Heads
I like the ex 514 single 4, the TrickFlow is also very nice, both are comparable price wise.
studly wrote:anybody know? Nitrous application but large cubes 600 plus
We've tried them all, meaning the old style Ford Motorsports manifold, the EX-514, and the current new style TFS A-460. For your 600+CID nitrous application, you will want the new TFS A-460 manifold. When I say tried them all, that was both on the dyno and actual drag strip testing.
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:studly wrote:anybody know? Nitrous application but large cubes 600 plus
Hope this helps,
Charlie
I don't know about the power level however, actually Charlie, a customer of mine changed to the new improved Trick Flow manifold form the his older "flat-floor" plenum TFS manifold on consecutive weekends at the strip and on "all engine NA" it was a bit quicker but, when using his nitrous, (a plate of around 200 horsepower), it was a bit slower than before.
It could be attributed to the slightly larger plenum of the "flat-floor" intake or the distribution taking place of the nitrous plate or even air density, with and without the nitrous in use..
I wish I knew what it really was though, LOL.
You are probably going to love a little on any of them. One thing I would agree with is that the TrickFlow is probably the most readily available and would certainly fill your needs. The EX514 is a great intake, but there is usually a wait, the Motorsport you can usually be found used, but isn't quite as good as the new offerings. Either way you can meet your goals.
Randy,
I noticed that he said 600+CID and based on that, then it's been our experience that the new style TFS A-460 would be the better manifold. However, I do know that the older style Motorsports manifold seems to work better on smaller A-460 headed engines. Therefore I think the CID of the intended engine is a very important part of the equation.
Charlie
Charlie
Another option would be a Holmes style, or Newer style TFS tunnel ram with a single top, or do a custom split deal, but that's another conversation altogether.
Barney wrote:Another option would be a Holmes style, or Newer style TFS tunnel ram with a single top, or do a custom split deal, but that's another conversation altogether.
Long live Holmes!
c.evans wrote:Randy,
Charlie
I am NOT talking about the "Motorsport" manifold.
These were BOTH the taller TFS manifolds, just the floor of the plenums seemed to be different.
His engine is a 572 ... bigger 4.600" bore, shorter 4.300" stroke.
About a year ago, I asked Lem about this when it happened and he confirmed that TFS did make a running change to their A manifold plenum floor.
There are two versions of the 'new' TFS manifold [the ones with the windsor water neck] the last several years the newer new manifold has a convex plenum floor.
Do you have a part number for the new TFS intake, this will be a Fogger system so i do not think the floor will effect the fogger system. this Motor should make 900 plus on motor and have 400-500 spray.
studly- Posts : 512
» 601ci C460 heads, single dominator cast intake on gas.
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» WTB: A441 cast single intake manifold
» Distributor for Trickflow R series A460 intake. Single 4500
» ISO- A460 single dommi intake
