looking for 429/460 stuff
QtrWarrior
429 Powered 84
looking for 429/460 stuff Empty looking for 429/460 stuff
Post  429 Powered 84 June 23rd 2012, 5:30 pm
I want to build a mild consistant pain in the butt 429! I have a stock 69 low miles that I want to cam it, intake,carb. What Im askin is if anyone has stuff layinn around that they don't need,want around that I could get very reasonable would help me out tremendously. Not asking for free but whatever you want to do?
Thanks Dan
429 Powered 84
429 Powered 84
looking for 429/460 stuff Empty Re: looking for 429/460 stuff
Post  QtrWarrior June 23rd 2012, 7:32 pm
Dan,
I have a couple of small Hyd cams..nothing over .508 lift if you're interested...
QtrWarrior
QtrWarrior
Post  DanH June 24th 2012, 3:56 am
429 Powered 84 wrote:I want to build a mild consistant pain in the butt 429! I have a stock 69 low miles that I want to cam it, intake,carb. What Im askin is if anyone has stuff layinn around that they don't need,want around that I could get very reasonable would help me out tremendously. Not asking for free but whatever you want to do?
Thanks Dan
got a new rpm intake and Holley (like new) 870 $450 plus ride
DanH
looking for 429/460 stuff Empty Pushrods
Post  manofmerc July 27th 2012, 6:54 am
I have a nice used set of 5/16 manley pushrods .Length 8.500 if you have factory heads with guideplates these work good .$40 plus shipping I also have a set of crane 5/16 8.656 long used also .This length I believe works better for d3 heads $40 plus shipping .The cranes are for guideplates also .I had the manleys on a 460 with dooe r heads with a milled block and heads the pushrod geomentry had a nice centered pattern on the valve stems .Doug 678 603 8400
manofmerc
Post  OldRed70 July 27th 2012, 6:27 pm
Dan
I have a Used Comp Hyd Cam, Lifters and A set of Comp Roller Aluminum Rockers If you are Interested
Cam is a Magnum 292H 560" lift 292" Duration hyd Flat Tappet
Rockers are 1.73 's
All have less than 8000 miles on them and less than 30 passes @ the track.
OldRed70
OldRed70
looking for 429/460 stuff Empty update
Post  429 Powered 84 July 28th 2012, 5:12 pm
I did find a fairly large HYD FT cam an lifters new so that's taken care of, carb has been located and on it's way. Got a smoken deal on a set of ladder bars from a forum member here.
I am looking around for a Ford Iron SCJ intake square bore.
I will be in touch on the push rods listed!
In need of some C6 stuff, Pan, converter, ect.
also lookin for couple gauges, oil, temp,fuel pressure.
anyone got a set of mini tubs they didn't use?
rear coilover shocks.
Ignition stuff msd, mallory, crane? whatever?
THESE PARTS DO NOT HAVE TO BE PERFECT BUT USABLE!
ALL HELP IS GREATLY APPRECIATED!
THANKS TO THOSE WHO HAVE ALREADY BEEN HELLPIN ME OUT THAT VERY COOL!!!! Cool Cool
I do have a couple stock Glide case that I could do some tradin with on stuff?
[b]
Thanks Dan
429 Powered 84
429 Powered 84
Post  schmitty July 28th 2012, 6:54 pm
Dan, ask Doug what became of my old locked out Duraspark dizzy, and I have an old MSD 6A laying around that I would part with reasonable. If Doug still has that dizzy, you can have it. There is one on Ebay for $50 now, so I'd do $50 shipped. Cool
Post  429 Powered 84 July 28th 2012, 8:46 pm
Thanks Rob I will ask him and might just have to take you up on the other.
Dan
429 Powered 84
429 Powered 84
