main restrictors
dave d
main restrictors
Do any of you engine builders use main restrictors when running stroker motors,running 4.5 stroke with 6.8 rod-street 545. I've had some people tell me the reason i can't get oil pressure is because of no restrictors and the machine shop that did my motor didn't put any in. Running solid roller cam,made 5 good passes fri at ethridge running about 45-50 lbs of pressure, number 6 pass lost oil pressure. Help Thanks dave
dave d- Posts : 809
Re: main restrictors
Thanks ,also the pushrods that I'm running have 90thousand oil hole ---is this to much seems to be getting alot of oil up on top when priming
dave d- Posts : 809
are your lifters in with the bars down?
oil holes are away from oil galley, check that one all ready,Thanks,,sorry i didn't get to meet you over the weekend next time
dave d- Posts : 809
i walked up where you were parked but did'nt see you but i did see you go down the track.dave d wrote:oil holes are away from oil galley, check that one all ready,Thanks,,sorry i didn't get to meet you over the weekend next time
What lifters are you running...?
I never restrict oil to the cam bearings, (unless it's a roller cam bearing where the cage blocks the hole itself). For that long stroke, I do machine the slot in the main bearing to a 9/32" hole aligning with the block oil feed hole to that main.
Some people only "hole" the center three mains and some claim even THAT is totally unnecessary.
dave d wrote:Do any of you engine builders use main restrictors when running stroker motors,running 4.5 stroke with 6.8 rod-street 545. I've had some people tell me the reason i can't get oil pressure is because of no restrictors and the machine shop that did my motor didn't put any in. Running solid roller cam,made 5 good passes fri at ethridge running about 45-50 lbs of pressure, number 6 pass lost oil pressure. Help Thanks dave
YES, solid roller cam we use them, feel free to call me, but you may have more then one problem
BOSS 429- Posts : 2371
BOSS 429 wrote:dave d wrote:Do any of you engine builders use main restrictors when running stroker motors,running 4.5 stroke with 6.8 rod-street 545. I've had some people tell me the reason i can't get oil pressure is because of no restrictors and the machine shop that did my motor didn't put any in. Running solid roller cam,made 5 good passes fri at ethridge running about 45-50 lbs of pressure, number 6 pass lost oil pressure. Help Thanks dave
^^^^^ X2 ^^^^^
I've used the FRPP ones on all of my race stuff, and have never had an issue with pressure due to the restrictors themselves. Luckily, none at all...
ThndrChkn- Posts : 2216
» Bearing clearance, oil restrictors, and cam questions
» Oil restrictors?
» Restrictors
» Lifter oil restrictors
» A460 block oil restrictors
» Oil restrictors?
» Restrictors
