Tires suggestions please
racinghabbit
Tires suggestions please Empty Tires suggestions please
Post  racinghabbit July 24th 2012, 12:59 pm
looking to 1/8 mile drag my mud truck. looking for advice on what tires to use(size)... 600 hp big block with the rearend spooled. 3.50 gears , C6, truck weights 4800lbs.
racinghabbit
racinghabbit
Tires suggestions please Empty Re: Tires suggestions please
Post  69F100 July 29th 2012, 12:17 am
are you wanting to run slicks if so I would say a 28x10.5 stiff sidewall with that weight the shorter tire will help on the 1/8 mile times with your gears what are you turn the engine in rpms you can go to wallace racing with your hp,rpm and tire size to get close
Post  cool40 July 29th 2012, 2:05 am
what ever size you decide on get a M/T. Smile
Post  DILLIGASDAVE July 31st 2012, 12:19 am
If it's a 16" rim your slick height/OD choices are going to be limited a little vs what's available out there for a 15" rim.
Hoosier or M/T for the brand if it's a smaller OD slick.
Post  racinghabbit September 11th 2012, 5:36 pm
fyi , anything under a 30in tires on my truck just does really good burnouts..
racinghabbit
racinghabbit
Post  quick 52 September 17th 2012, 9:58 am
mt dr 315x60x15 hook very good and r 30" tall
quick 52
Post  HorsinAround September 21st 2012, 9:26 am
Several of the trucks I've seen at a couple of the local tracks have been shod with 32-12.5's. and it's got me to wondering the same thing, what size/width. My motor build should be closer to the 700hp mark though, and I am looking at running 4.10's with a spool. It currently has 3.73's with a posi.
http://www.frontpagefab.com
Post  f250mike September 21st 2012, 3:19 pm
I have 29.5x10.50 hoosiers on mine with 4.10 gears and spool. The truck has less that 600hp though.
We spin a little on the launch but it's coilover shock/spring related. Just can't swing buying the good ones.
f250mike
f250mike
