C-6 Help
C-6 Help Empty C-6 Help
Post  charchar1207 July 26th 2012, 4:44 pm
Can you convert a 2 wheel drive C-6 to a 4x4? Can you switch parts from a C-6 that bolts up to a small block and put them on a 460 C-6? I have a C-6 that bolts up to a small block.. and i have a 2 wheel drive C-6 that bolts up to a 460.. or do I have to find a C-6 4x4 that bolts up to a 460 block? Please help!
charchar1207
C-6 Help Empty Re: C-6 Help
Post  schmitty July 26th 2012, 6:51 pm
Yes you can change out the output shafts and the tail housing and make it a 4x4 version. The internals don't know what the housing is so yes they are all interchangable. Cool
Post  whitefield July 26th 2012, 10:05 pm
X2 on what he said UP There! cheers Arrow
whitefield
whitefield
Post  samiam July 27th 2012, 1:35 am
I used a car C-6in a 4x4, and instead of changeing parts around I used a divorced transfer case, you will need 1 extra drive line, worked for years
samiam
samiam
Post  Gregaust July 27th 2012, 5:12 am
The trans must be fully disassembled to swap the output shaft
Gregaust
