Hood to carb clearance ?
Hood to carb clearance ? Empty Hood to carb clearance ?
Post  whitefield July 27th 2012, 12:50 pm
Has anyone had hood to carb clearance issuses that resulted in low hp numbers ? or poor performance at the track?
whitefield
whitefield
Hood to carb clearance ? Empty Re: Hood to carb clearance ?
Post  Barney July 27th 2012, 1:35 pm
Yes, ideally you want 4 inches of carb to hood clearance.
Barney
Barney
Post  richter69 July 27th 2012, 5:16 pm
if its too close it can screw with the vent tubes and the air bleeds......you can always pull it off and run it to verify, just make sure you use big unrestrictive air cleaner of sorts.
Post  whitefield July 27th 2012, 8:29 pm
Thanks planned on doing that tonight , but just got in from helping my son mowe three big yards and weed it ! I am tuckerd out! try it tomorow night maybe Laughing
whitefield
whitefield
Post  whitefield July 28th 2012, 10:08 pm
so when we had it on the chassis dyno that could make it run rich at Idle and lean out on top end ?
whitefield
whitefield
Post  whitefield September 24th 2012, 12:53 pm
Running my car with hood on and hood off for the past two weekend at the same track . I have found that running the car with the hood off is worth 1tenth et. exhaust was also worth about 1tenth . Thanks for the input and I planning on picking up a new hood next weekend in BG.
whitefield
whitefield
Post  BM2271 November 29th 2012, 12:08 am
How close was your hood to the carb?
BM2271
Post  whitefield January 18th 2013, 3:58 pm
BM2271 wrote:How close was your hood to the carb?
The air horns or vent tube were 1/4" a way from the hood . Runs better now but still not getting the et or mph I was looking for!
whitefield
whitefield
