Need help!
Need help!
I have a 92 bronco on a 78 chassis
40" tires
3:73 gears
Stock C6 Trans
Had a bone stock 460 in it
Well it came time to rebuild
So I did a stock rebuild with
429 timing set
Preformer intake
And a lunati cam it's been a couple years now but I think this is the cam or close to it
Advertised Duration (Int/Exh): 250/256
Duration @ .050 (Int/Exh): 207/213
Gross Valve Lift (Int/Exh): .503/.535
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: idle-5000
Includes: Cam Only
I finally got it going and it's like it's not getting fuel
It's
Extremely week
Won't pull past 3k rpm on the floor
And Cuts in and out
So I borrowed a holley blue and it was better but not fixed
It's has one of the crappy 600 cfm Holley carbs (not 4150)
Do I need a carb ?
If so which one?
Thanks Micah
40" tires
3:73 gears
Stock C6 Trans
429 timing set
Preformer intake
LSA/ICL: 112/108
Includes: Cam Only
It's
Extremely week
And Cuts in and out
Do I need a carb ?
If so which one?
Thanks Micah
Big block fox 339- Posts : 279
need help
Check your dizzy,and put a 750 vac.sec. HOLLEY3310, and let them horses run!.Hope this helps,MAVMAN
1970 ford maverick- Posts : 180
Re: Need help!
1970 ford maverick wrote: Check your dizzy,and put a 750 vac.sec. HOLLEY3310, and let them horses run!.Hope this helps,MAVMAN
Thanks I really think a carb will fix it.
What Fuel pump ?
Do I need a return with a holley blue?
need help
The holley blue pump works great,maybe a reg. Should be good to go with out a return. GIT-R-DONE !Big block fox 339 wrote:1970 ford maverick wrote: Check your dizzy,and put a 750 vac.sec. HOLLEY3310, and let them horses run!.Hope this helps,MAVMAN
What Fuel pump ?
Re: Need help!
BOSS 429 wrote:have you checked your timing?
Yes sir that was the first thing I did
It's been a while since ive worked on it I've done forgot what it was
The vac/mech advance is working it was like 13/35 or something close to that..... I think lol
