WTB intake
ThndrChkn
IcallhimGeorge
OldRedFord
WTB intake Empty WTB intake
Post  OldRedFord October 2nd 2009, 5:44 am
Factory intake OR a Edy Performer on the cheap.
OldRedFord
OldRedFord
WTB intake Empty Re: WTB intake
Post  IcallhimGeorge October 2nd 2009, 8:18 am
Ive got a couple factory intakes.
IcallhimGeorge
IcallhimGeorge
Post  ThndrChkn October 2nd 2009, 9:45 am
Tim, I have a factory SCJ iron intake you can have for $75.00 plus 1/2 on the shipping... It works as goos a Stealth, just a wee bit heavier... Cool Cool Very Happy
Doug... Cool
ThndrChkn
ThndrChkn
Post  OldRedFord October 2nd 2009, 1:09 pm
Would a Holley 3310 work on a factory intake?
http://www.summitracing.com/parts/HLY-65-3310S/
OldRedFord
OldRedFord
Post  ThndrChkn October 2nd 2009, 1:47 pm
Yes it will... What is your intended use...? From the sounds of it, you're just building a pretty much stocker/driver...? The 3310 will work, and you really don't "need" the heat riser in the intake AS I "don't" believe the new carb will come with the attachment or not... I could be mistaken though... I have always just capped them off and haven't had an issue... But as far as fitment, it will work... And I wouldn't put less than a 750 on it...
Doug... Cool
ThndrChkn
ThndrChkn
Post  IcallhimGeorge October 2nd 2009, 1:57 pm
the stock intakes I have are a spreadbore style.
Wont you need a spacer so the front butterflys will clear the smaller intake bores?
IcallhimGeorge
IcallhimGeorge
Post  the Coug October 2nd 2009, 2:02 pm
Kris the CJ intake was spread bore carb and the SCJ was std Holley pattern
Post  OldRedFord October 2nd 2009, 2:16 pm
1bad521 wrote:Yes it will... What is your intended use...? From the sounds of it, you're just building a pretty much stocker/driver...? The 3310 will work, and you really don't "need" the heat riser in the intake AS I "don't" believe the new carb will come with the attachment or not... I could be mistaken though... I have always just capped them off and haven't had an issue... But as far as fitment, it will work... And I wouldn't put less than a 750 on it...
Doug... Cool
Just a driver. And faced with the school situation with my brother.(driving my Ranger). Wishing I had not tossed all the factory 460 stuff I had. Embarassed
This build went from a performance goal to...just run it...in a few hrs.
I asked about the heat riser because I have a Motorcraft 4350 laying on the bench, but then looked into using the Holley. Doug, are you saying I could cap off that little tube on the carb and it not be a issue? If I ran the 4350, and a stock intake thats about $400 less I have to come up with.
OldRedFord
OldRedFord
WTB intake Empty Heat riser.
Post  fordman460 October 2nd 2009, 2:39 pm
I think he is talking about the tube for the choke on your 4350. By the way, there are three versions of that intake. Square bore Holley (SCJ), spread bore quadrajet (CJ), and spread bore 4350 (PI).
fordman460
fordman460
Post  OldRedFord October 5th 2009, 4:11 am
fordman460 wrote:I think he is talking about the tube for the choke on your 4350. By the way, there are three versions of that intake. Square bore Holley (SCJ), spread bore quadrajet (CJ), and spread bore 4350 (PI).
Yea thats what I am talking about. Whatever that tube does.
OldRedFord
OldRedFord
Post  nuclearcobra October 11th 2009, 7:36 am
Did ya find one yet ? if not i got a regular iron 4 v intake that is square bore.
nuclearcobra
nuclearcobra
Post  69F100 October 11th 2009, 8:15 am
if you hadn't found one i will check i think i still have a foctory one you are welcome to it if you want to take few hours ride down
Post  69F100 October 11th 2009, 12:44 pm
I looked after church and I still have it ,it is a d6ve it will need a good cleaning
WTB intake Empty square 4bbl 460 intake manifold
Post  TurboJim October 20th 2009, 12:56 am
I've got a square bore 4bbl cast iron intake manifold that is in real good shape. $60 plus shipping.
TurboJim
http://www.suspensionforkparts.net
Post  OldRedFord October 20th 2009, 1:17 pm
I got one. Thanks guys. Very Happy
OldRedFord
OldRedFord
