What Should it Run??
Instead of going back to my 501 Stroker.. I was thinking of running just a 460 in my 1989 back halfed/ladder bar Ford Mustang that weighs around 2800lbs with me in it and the following Mods..
D1VE/D9TE Block Bored .30 over (466)
Comp Cam .715/.710 lift
6.605 H Beams
Stock Crank
Blue Thunder Heads
Approx 13:5-14:1 Compression
Crower Roller Lifters
Edelbrock Victor 460 Dominator Intake
1050 Holley Dominator Carb
Powerglide
5300 Stall
Ford 9"
Strange Spool with 4:30 Gears
C12 Fuel
Sure I'm missing a bunch.. but I was hoping for the car to run around 9.60-9.70's@136-138mph.. just about where it was with the 501.. Can it be done?.
6.605 H Beams
Stock Crank
Blue Thunder Heads
Powerglide
5300 Stall
Ford 9"
C12 Fuel
1faststang- Posts : 129
Re: What Should it Run??
Should do it easily
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Should do it easily
Here's Hoping...Just weighing my Options!.. If theres no need to stroke it.. I won't.. That didn't sound good ..lol
My mustang went 6.21 saturday night in the 1/8 @ 109mph at 3080 lbs. with a .060 460 with dove-c heads that's been together since 2004 ,that'll translate to around 9.80 in the 1/4
56Tbird wrote:My mustang went 6.21 saturday night in the 1/8 @ 109mph at 3080 lbs. with a .060 460 with dove-c heads that's been together since 2004 ,that'll translate to around 9.80 in the 1/4
Wow!..Sweet ET..What Compression ratio?.Sounds like you've had some good luck with it being together since 2004.
Not sure on compression.It's got flat tops and 72cc heads.It has been good to me,and to my driver now also!If it survives this season ,hopefully we'll pull it and freshen it up
56Tbird wrote:Not sure on compression.It's got flat tops and 72cc heads.It has been good to me,and to my driver now also!If it survives this season ,hopefully we'll pull it and freshen it up
Probably a good idea
Do you know if you're running just stock rods and crank??
Anyone else??
Stock crank with H-beam rods and floating pins with Probe pistons.
56Tbird wrote:Stock crank with H-beam rods and floating pins with Probe pistons.
And a .60 Bore?.. sounds like a decent combo!
It's won a bunch of money and races.I hope to put it in another block this winter,I'm sure it'll need a bore job. It's as fast as the car needs to be anyway.
56Tbird wrote:It's won a bunch of money and races.I hope to put it in another block this winter,I'm sure it'll need a bore job. It's as fast as the car needs to be anyway.
Sweet!!.. You run both 1/8 and 1/4 mile?.
I run both with my Tbird,the Mustang is set up for 1/8 mile only
56Tbird wrote:I run both with my Tbird,the Mustang is set up for 1/8 mile only
BBF in the TBird?
I had a 472 w stock crank and block, H beams, heavy ass trw dome pistons, some TFS streets w minimal work, sold roller, victor intake, alky injected. ran 9.60's in the heat at 3100 #'s
this was with a good c4 but if the converter is right it should be faster anyway w the glide.
Harold Webster's 466 w/C9's and a glide ran some 5.80's in a 87 cougar. #2666 w/a #300 driver. Sorry Harold
richter69 wrote:I had a 472 w stock crank and block, H beams, heavy ass trw dome pistons, some TFS streets w minimal work, sold roller, victor intake, alky injected. ran 9.60's in the heat at 3100 #'s
Thanks for your input!.. The Converter comes on at about 5300rpm.. its a Transmission Specialities 9" Spragless Unit.
I had Ross Pistons in the 501 before the lifter let go and ruined everything.. Think I may try a set of Probes this time round... with maybe 13:5 or 14:1 Compression Ratio??..not sure what to go with..I only plan on using C12
**Updated on what I think I'm going to have built**.. Trying to get my best bang for the buck..lol
6.605 H Beams
Stock Crank
Blue Thunder Heads
Powerglide
5300 Stall
Ford 9"
C12 Fuel
6.605 H Beams
Stock Crank
Blue Thunder Heads
Powerglide
5300 Stall
Ford 9"
C12 Fuel
