1993 Mustang 460 Swap Issues
hey guys i have a 1993 Mustang LX, removed the 4 cyl and built a 460 to drop in. I bought the Ford Racing oil pan swap kit, and the hooker header engine mount swap kit hkr-12678. everything is mounted up, trans cross member, motor mounts bolted in and all and the motor sits great and center however the front of the motor sits a little high for my liking. i put a level on the manifold and the front needs to go down mabe a 1/4 of an inch. idk if this is normal or what. Just wondering if anyone has any insight on this or what. Please let me know guys! thanks alot.
mbgt02- Posts : 2
Re: 1993 Mustang 460 Swap Issues
https://i.servimg.com/u/f33/17/73/48/16/img_1011.jpg
https://i.servimg.com/u/f33/17/73/48/16/img_1012.jpg
https://i.servimg.com/u/f33/17/73/48/16/img_1013.jpg
mbgt02- Posts : 2
yes its is normal and I dont like it either,however ,I switch to a engine plate level the engine and no better performance
gforce460- Posts : 4
You can install k member spacers to help levelit out?
bigblockfox.com
not a big issue but when you level the motor you might need to mod the steering shaft due to header clearance issues
justintx75- Posts : 5
» 1993 coupe mustang 5.0 $6500.00 / 1988 mustang coupe body $900.00
» Parting 1993 Mustang LX convertible
» 1993 Mustang Notch True Street Car
» 1993 mustang GT body $1000.00 / 1991 mustang GT body $500.00
» can a 1993 Crown Vic 8.8 rear work in a 1992 ford mustang?
