JE/SRP Pistons.. will they work
JE/SRP Pistons.. will they work Empty JE/SRP Pistons.. will they work
Post  1faststang August 23rd 2012, 2:50 pm
Just wondering if JE 170877 and SRP 150727 Ford 460 stroker pistons will work with Blue Thunder Cylinder Heads with 73CC, 2.250 Intake Valve, and 1.880 Exhaust Valve??. Thanks!
http://www.jepistons.com/Products/170877.aspx
http://www.jepistons.com/Products/150727.aspx
1faststang
1faststang
JE/SRP Pistons.. will they work Empty Re: JE/SRP Pistons.. will they work
Post  the Coug August 23rd 2012, 4:05 pm
yes the only thing is the 170877 has a .990 pin and factory has 1.040
Post  1faststang August 23rd 2012, 4:44 pm
the Coug wrote:yes the only thing is the 170877 has a .990 pin and factory has 1.040
Didn't know that..Thanks!!
1faststang
1faststang
Post  1faststang August 23rd 2012, 4:51 pm
The Paper work I received with the car says the Rods are Eagle CRS68003D.. Looks like they have a .990 Pin
http://www.excessiveracing.com/esp-crs68003d.aspx
1faststang
1faststang
Post  the Coug August 23rd 2012, 5:25 pm
ok if you have a 4.3 crank with 6.8 rods those pistons will get you 521 cubes
Post  1faststang August 23rd 2012, 7:36 pm
the Coug wrote:ok if you have a 4.3 crank with 6.8 rods those pistons will get you 521 cubes
What about a 4.1400 Crank (501)??
1faststang
1faststang
Post  the Coug August 23rd 2012, 9:48 pm
They will work but you will be .080 down the hole...
try these they are for 4.14 stroke and 6.8 rods they are 1.42 comp height http://www.jepistons.com/Products/150727.aspx
Post  1faststang August 24th 2012, 11:59 am
the Coug wrote:They will work but you will be .080 down the hole...
Thats the route I was thinking on going 4.14 crank with a 6.8 rod.. should make a nice lil 501.. I'm hoping???
1faststang
1faststang
