Water in oil???
ThndrChkn
sixtynineford
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Water in oil???
i know where you coming from on the heater core my daughter got a 95 gram am gt my dad gave her i fixed the a/c but still havn't fixed the heater core you got to pull the dash out and i hate messing with a dash
Re: Water in oil???
Well finally got some shop time and tore motor down. I have very obvious head gasket leak at the top of cylinder leaking into lifter gallery. I have some pics if someone will tell me the easiest way to post on here. I was using the ford motorsports felpro gaskets and guess need to figure out which is best gasket to put back in. Probably got hurt on couple of test drives the first weekend I fired it up on some 91 octane gas and drove around some didnt get on it much but did hear it detonate. The bearings looked decent for the amount of water in the oil, but did have weird looking hot spots on them suspect from bad tune or detonation.
sixtynineford- Posts : 48
Re: Water in oil???
check the head and block for straitness, you may have a slight warp.....
the Coug- Posts : 3055
Re: Water in oil???
photobucket is the easiest for me
Page 2 of 2 • 1, 2
» Switched from mech water pump to Moroso electric water pump
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
» 70-outlaw is just about ready
» BBF using water
» Water in The Oil! HELP!
» BBF using water
Page 2 of 2
