Coil over question
Coil over question Empty Coil over question
Post  Mike R August 29th 2012, 9:15 pm
I'm seriously thinking about putting coil overs under my Fairmont wagon. What length shocks and what stroke do I want and what should the spring rate be?
Coil over question Empty Re: Coil over question
Post  cool40 August 29th 2012, 10:27 pm
the spring rate,length,and stroke all depend on the weight and use of the car.i use 5" stroke strange dbl adj's with 130#spring. if your gona do it be sure and get a good dbl adj shock,you'll be happy you did. Smile
Post  yellowhorse7 August 30th 2012, 7:47 pm
cool40 wrote: if your gona do it be sure and get a good dbl adj shock,you'll be happy you did. Smile
Just be ready for a long learning curve, unless of course you have them huge cheater tires Wink
yellowhorse7
yellowhorse7
Post  maverick August 30th 2012, 8:21 pm
Wish I had a Fairmont wagon. It could be a friggin' Xerox machine in the brackets. Cool
Post  cool40 August 30th 2012, 10:47 pm
what kinda shock would you use for the baby tires? jocolor
Post  bigblok2000ranger August 30th 2012, 11:06 pm
cool40 wrote:the spring rate,length,and stroke all depend on the weight and use of the car.i use 5" stroke strange dbl adj's with 130#spring. if your gona do it be sure and get a good dbl adj shock,you'll be happy you did. Smile
Not to hijack but being as someone already brought it up how would one determine the best stroke for a combination?
Example my truck can only have 3 inchs of suspension compression before it will hit the bump stops but I get 1-2" inchs of body seperation so does that mean a 5 inch stroke would work best?
Long??? Just got my suspension working decent should I leave the single adjustable??? Got some tuning tips?
bigblok2000ranger
bigblok2000ranger
Post  yellowhorse7 August 31st 2012, 6:55 pm
Of course a DA is better than a SA....
All I'm saying is that it takes a bit of a learning curve to get the DA's figured out, at least for us small-tired guys.
yellowhorse7
yellowhorse7
Post  yellowhorse7 August 31st 2012, 6:57 pm
Yep....full loose in the front isn't optimal
yellowhorse7
yellowhorse7
Post  cool40 August 31st 2012, 9:01 pm
yellowhorse7 wrote:Of course a DA is better than a SA....
its kinda like having a 4-link,all that adjustment but only one spot is "best". Smile
Post  bigblok2000ranger August 31st 2012, 9:54 pm
LOL, Well I have s/a with ladder bars and leafsprings with housing floaters and 90/10 up front. 9 ways from Calvert set in the #5 haven't got to the point of working on adjusting them yet in the rear. It will be getting d/a with coil-overs probably over the winter mainly in the interest of losing weight (with the added adjustability as a bonus).
P.S. Hey Tony looks like the little tires are gonna work Wink
bigblok2000ranger
bigblok2000ranger
Post  HorsinAround October 30th 2012, 1:17 pm
With Coil overs on the front, do you use the OE spring rate as a starting point to determine what spring to get? I'm in this boat now. Trying to decide if I should get lowering springs or just go to coil overs and move on. My application is an F150 with a BBF.. Oe spring rate is 337 with a load rating of 1258.
http://www.frontpagefab.com
