112cl v/s 110cl or 111cl
112cl v/s 110cl or 111cl Empty 112cl v/s 110cl or 111cl
Post  tconnection September 13th 2012, 7:40 pm
I end up putting this cam in on a 112cl for n/a. Would the 110 and 111 be alot quicker? C6 trans, 5500 stall, 373 gear, 28 0r 29in tire 3000lb car.
839/780 283-320@.050 316-340 adv. 114cl 114ls
tconnection
112cl v/s 110cl or 111cl Empty Re: 112cl v/s 110cl or 111cl
Post  IDT-572 September 13th 2012, 10:23 pm
Hard to answer this give us a rundown of the engine parameters and use. Usually it will just move the toque peak and hp peaks around unless the engine is wanting a valve event it don't have.
Gain some on one lose some on the other. and vise versa.
Post  tconnection September 13th 2012, 10:50 pm
Drag race, 580ci, 13:7 to 14:1cr, ported a460 heads with 2.35 int 1.88 ex, flowing maybe 440cfm on the int.
tconnection
Post  rmcomprandy September 13th 2012, 11:55 pm
tconnection wrote:Drag race, 580ci, 13:7 to 14:1cr, ported a460 heads with 2.35 int 1.88 ex, flowing maybe 440cfm on the int.
ONE degree either way and you are probably going to move 5 horsepower around; I hope that much isn't going to make you a lot quicker, LOL.
Post  tconnection September 14th 2012, 12:37 am
Ok, thanks.
tconnection
