I swapped my stealth for a victor intake and found a problem!!
+6
4604X4
f250mike
10 posters
I have 5 out of 8 intake ports that are black. I'm guessing I have some seriuos valve to seat issues.
I run a solid cam and check the lash every 3 races. So I know the rockers aren't to tight.
The dove heads were built back in 2005 and have lots of mud drag and 1/4 mile passes on them. Maybe 400 passes in total.
Any ideas?
mike
Any ideas?
mike
f250mike- Posts : 628
Re: I swapped my stealth for a victor intake and found a problem!!
Mike run it pull the heads over the winter amd do a valve job you dont have many more races this year left do you.
f250mike wrote:I have 5 out of 8 intake ports that are black. I'm guessing I have some seriuos valve to seat issues.
Any ideas?
mike
FOUR HUNDRED passes on a race engine ...?
I would say it is well past time to get inside and look over things which do tend to wear out.
Compression test and a leak down test will give you some indications of whats going on.
Also look for leaky intake gaskets.
Randy, I never really considered it a race engine .
It's a low budget deal that I suppose has been neglected a little.
It's been running high 11 second passes. Do you suppose the exhaust valves are about the same?
Guess I'll find out soon.
Dave, I looked the intake gasket over real good and it appeared to be sealing fine.
Jim, I have 2 more points races and I'm done for the year. I might try to get these heads freshened and make a couple TnT days before snow flies.
Thanks guys
Thanks guys
What are the engine specs?
4604X4- Posts : 108
It's a .060" over D9 block with stock crank, truck rods, and KB137 pistons.
Ported Dove heads with 2.19in./1.76ex valves. no flow #'s
Cam is a solid flat tappet. 254/261 @ .050 duration. .615/.635 lift
I was running a stealth with 850 holley. The victor is on it now with the 850.
Ok, today I tried out the victor intake on the truck.
This spring with similar air and temp the truck went best of 11.76.
The victor swap with no other changes netted me a 11.44. https://2img.net/h/i92.photobucket.com/albums/l26/mudmike/9-22-2012timeslip_zps0065cef4.jpg
I set a goal to run 11.60 this year. I think after today I have next years goal covered also!!
Thanks for the advice Rich Wilhelm!!!!!!!!!! The victor made a huge difference
One more race and I can get the leaky valves and the port match taken care of.
mike
mike
Congrats on your new best time 3 tenths improvement is good for a intake change.
Later Mark.
Later Mark.
Mark Miller- Posts : 1958
rmcomprandy wrote:f250mike wrote:I have 5 out of 8 intake ports that are black. I'm guessing I have some seriuos valve to seat issues.
Any ideas?
mike
As Sir Randy writes, all things being as they are, 400 (+/-) runs, I would think there would be a bit of "dirt" up the intake runners (tract). I would be curious at the end of your season, if the Victor's runners are discolored! Let me commend you on a good build that has brought you excellent service. Again as Randy wrote, time to give her the once over!
JM$0.02,
Dave.
LivermoreDave- Posts : 972
mike[/quote]
Your welcome mike, Now you know how I feel about the torino engine,over 600 passes,and 10 years of run time on it, 8 different intakes,( 3 differnt victor intakes ) 10 different carbs 4 different converters tried ,5 different gear ratios, including a low gear set in the c6,2 different c6 trans ,valve bodies,and then we added nos,lol it needs a freshen,but we learnd some things testing .
BOSS 429- Posts : 2372
mike
Your welcome mike, Now you know how I feel about the torino engine,over 600 passes,and 10 years of run time on it, 8 different intakes,( 3 differnt victor intakes ) 10 different carbs 4 different converters tried ,5 different gear ratios, including a low gear set in the c6,2 different c6 trans ,valve bodies,and then we added nos,lol it needs a freshen,but we learnd some things testing .[/quote]
That Torino motor runs pretty good....
yellowhorse7- Posts : 1382
mike
That Torino motor runs pretty good....[/quote]i houht it was retired to cruise night beauty queen duty?
That Torino motor runs pretty good....QUOTE;
lol,you should know, you have its sister
mike
I thouht it was retired to cruise night beauty queen duty?[/quote] < no,I should,but for now its just resting
» Oil in the intake everywhere
» Convertor swap and c6 build
» Automatic o/d problem
» found my problem
» Timing chain help
» found my problem
» Timing chain help
