Need help PLZ
bosshoss
zbob
Big block fox 339
Need help PLZ
Ok I've been trying to get my bronco to run right for years now I gave up for a while now I'm back at it.
It's a freshly rebuilt 460
Stock rebuild kit
Over 30
Lunati voodoo cam 252-262 dur 530 lift
Performer intake
429 timing set
Stock ignition
It's been sitting a while after the rebuild and I decided to finish her up and get her running
So she started fine and revs fine
But it will not pull under a load it won't turn past 3k on the floor
So I checked the timing it's 13 initial 35 total
So I thought maybe its the fuel system
A buddy let me borrow a complete fuel system so it's not that.
I checked the cam it's dot to dot
Checked the compression it's 140-150 on all 8
It barely will crank now and blows back threw the carb
Could it be the stock ignition ??
I really don't know what else to check I really wanna take my little boy riding in it
So any help will be greatly appreciated
Thanks Micah
Stock rebuild kit
Over 30
Performer intake
429 timing set
Stock ignition
Thanks Micah
Big block fox 339- Posts : 279
Re: Need help PLZ
What carb and have you put a vacuum gauge on it to see what it is doing at 3000 rpm?
jasonf- BBF CONTRIBUTOR
Re: Need help PLZ
jasonf wrote:What carb and have you put a vacuum gauge on it to see what it is doing at 3000 rpm?
It's a holly 850 with a proform body and it wouldn't run with my 600 cfm holly either
It had a mechanic pump and a 600 holly it wouldn't run
I put my buddy's 850, blue pump and regulator and no change
Didn't check vacuum and it won't crank now
Re: Need help PLZ
did you put a new cam in it?
Re: Need help PLZ
cool40 wrote:did you put a new cam in it?
No sir just new lifters
That cam has been in there a while
Re: Need help PLZ
how are you adjusting the valves?
zbob- Posts : 271
Re: Need help PLZ
zbob wrote:how are you adjusting the valves?
Hmm it's been awhile since I put it together
Its stock rockers so I think just bolted down
Re: Need help PLZ
Plugged exhaust system?
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Re: Need help PLZ
bosshoss wrote:Plugged exhaust system?
dkp
I dont think so it has Open headers lol
Re: Need help PLZ
When you say it wont crank. Do you mean the starter engages but will not turn the engine over or there is nothing happening at all.
If the starter is having trouble turning it over is it siezed? Pistons to tight in bores? Bearings to tight on crank? mechanical binding?
dkp
dkp
Re: Need help PLZ
bosshoss wrote:When you say it wont crank. Do you mean the starter engages but will not turn the engine over or there is nothing happening at all.
dkp
No sir spins fine just spitting and sputtering and popping out the carb.
Re: Need help PLZ
Check timing, broke cam pin maybe ?
res0rli9- BBF CONTRIBUTOR
Re: Need help PLZ
res0rli9 wrote:Check timing, broke cam pin maybe ?
Both are good
Timing is 13&35
need some help
OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
1970 ford maverick- Posts : 180
Re: Need help PLZ
1970 ford maverick wrote: OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
They really ain't old but they are soot black
Re: Need help PLZ
Bad fuel? How long has it been sitting? If it's over 3 months get some fresh gas.
4604X4- Posts : 108
Re: Need help PLZ
4604X4 wrote:Bad fuel? How long has it been sitting? If it's over 3 months get some fresh gas.
My fuel is old so I by passed it with a small jug still wouldn't turn pass 2500 rpm
Re: Need help PLZ
I would change the plugs,if that don't help I would change the dizzy,do you have the vac. hooked up,and where?,maybe check your power valve also, I,ve had coils to drive me crazy too, so it may take some trouble shooting here. Hope this helps,MavMavBig block fox 339 wrote:1970 ford maverick wrote: OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
Re: Need help PLZ
1970 ford maverick wrote:I would change the plugs,if that don't help I would change the dizzy,do you have the vac. hooked up,and where?,maybe check your power valve also, I,ve had coils to drive me crazy too, so it may take some trouble shooting here. Hope this helps,MavMavBig block fox 339 wrote:1970 ford maverick wrote: OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
When I get to go back to the shop I'm gonna stick another dizzy and a msd ignition on it and try that.
Re: Need help PLZ
Big block fox 339 wrote:1970 ford maverick wrote:I would change the plugs,if that don't help I would change the dizzy,do you have the vac. hooked up,and where?,maybe check your power valve also, I,ve had coils to drive me crazy too, so it may take some trouble shooting here. Hope this helps,MavMavBig block fox 339 wrote:1970 ford maverick wrote: OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
and change them plugs
Re: Need help PLZ
x2 on the coil soundd like it is not firing right
Re: Need help PLZ
res0rli9 wrote:Big block fox 339 wrote:1970 ford maverick wrote:I would change the plugs,if that don't help I would change the dizzy,do you have the vac. hooked up,and where?,maybe check your power valve also, I,ve had coils to drive me crazy too, so it may take some trouble shooting here. Hope this helps,MavMavBig block fox 339 wrote:1970 ford maverick wrote: OK, have you thought about a new set of "Autolites"?, just a thought,MavMan
O yes
Re: Need help PLZ
69F100 wrote:x2 on the coil soundd like it is not firing right
I'm gonna change the coil put in a 6al and try a different dizzy.
I'm gonna start over from scratch check firing order and everything
Re: Need help PLZ
Big block fox 339 wrote:4604X4 wrote:Bad fuel? How long has it been sitting? If it's over 3 months get some fresh gas.
Be sure to drain the old fuel from the carb to (remove a lower fuel bowl moutning bolt to drain -or better yet remove the bowls and clean out). I just went through this myself a month ago. Old gas can make a big mess in the carburator.
4604X4- Posts : 108
