main cap bolt tensions
cooter
werneil
have started to put our eliminator604 together, as we obtained this block 2nd hand , still unused, with no touque/tension specs. any advice on crank cap tensions would be a great help, we have replaced the No1/No5 cap outer bolts with studs, we are running 6thou main bearing clearance and planed 80psi with 25w/50 . any advice is more than welcome
werneil- Posts : 12
Re: main cap bolt tensions
Cant help with the torque but 6 thou clearance, i assume thats a misprint?
cooter- Posts : 220
It's likely that someone here will have the torque specifications. If not, you can always contact Eliminator Products via telephone or through their website.werneil wrote:have started to put our eliminator604 together, as we obtained this block 2nd hand , still unused, with no touque/tension specs. any advice on crank cap tensions would be a great help, we have replaced the No1/No5 cap outer bolts with studs, we are running 6thou main bearing clearance and planed 80psi with 25w/50 . any advice is more than welcome
Assuming your rod clearances are also along the lines of your posted main bearing clearances: 20W-50 won't be adequate and most people running such high horsepower engine programs with similar bearing clearances are using engine oil coctails that historically have been single-viscosity 60-wt or 70-wt.
Paul
main studs 1 to 5 125 lb/ft
side bolts 2 3 4 105 lb/ft
side bolts 1 & 5 90 lb/ft
Max clearance that I've been running is .0045 to .005 with a 70 weight oil
I just scoped out the Tech sheet that Eliminator supplies with the blocks.
They call for 110 on the 1/2" studs - inner......80 on the 1/2" outer bolts and 60 for the 7/16" outer bolts on the front and rear. This is with oil.....
The 6 thousanths seems a little on the loose side. We typically like them closer .004"
If you need a scanned copy of the sheet, send me a PM
Thanks,
Keith
Thanks,
Keith
thank you very much for your replies, any and all advice is appreciated , and yes i stuffed up on the oil. not 25w/50 but 40w/70 !
werneil- Posts : 12
Whats the use for this engine?
this new engine is for my younger brothers low 10sec 68 f100, he pays the bills i'm the mechanic
werneil- Posts : 12
werneil wrote:this new engine is for my younger brothers low 10sec 68 f100, he pays the bills i'm the mechanic
You need to reconsider your clearances on that kind of application.
