Steel Dizzy Gear & IDT Block?
Steel Dizzy Gear & IDT Block? Empty Steel Dizzy Gear & IDT Block?
Post  AlkyPinto 6th October 2009, 13:08
Hi Guys,
I'm in the process of assembling an IDT Eliminator block.
I'm reusing a billet mechanical roller cam and my old
distributor with a "steel" (not iron) dizzy gear. Both
worked fine together in my old OEM block with no
unusual wear. The sheet that comes with the IDT
Eliminator block recommends drilling a .040" hole in
the oil galley plug by the distributor to help lubricate
"bronze" dizzy gears. I'm wondering if this is necessary
for "steel" dizzy gears? Its a drag only 645 ci application.
I'd rather not bleed off any oil psi unless its necessary.
Anybody know for sure?
Thanks,
Rich
AlkyPinto
AlkyPinto
http://www.RichKentRacing.com
Steel Dizzy Gear & IDT Block? Empty Re: Steel Dizzy Gear & IDT Block?
Post  chuck stevens 6th October 2009, 22:51
Not necessary but often recommended. I don't think you could measure any drop on pressure or volume.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  bbf-falcon 7th October 2009, 00:50
chuck stevens wrote:Not necessary but often recommended. I don't think you could measure any drop on pressure or volume.
X2
Post  AlkyPinto 8th October 2009, 13:20
Thanks guys! I'll leave the oil galley plug unaltered!
AlkyPinto
AlkyPinto
