found the low 1.50's last time out
+6
ThndrChkn
D. Sea
Greg_P
10 posters
Two back to back 1.51's. Not great, but much better than before. Now the car starts a little spinning about 10 feet out, and we will be working on that next time.
As always, any and all suggestions are welcome.
Greg
Greg
Greg_P- Posts : 1009
Re: found the low 1.50's last time out
Nice! It's not easy getting a land yacht to short time like that
D. Sea- Posts : 2768
Good deal Greg... If I'm not mistaken, as long as it's not blowing the tires off, you want a little bit of spin so as not to pull the engine down too much... I kept adding pressure to my rears because it wasn't getting any rotation at all... I added 1/4# at a time until my 60's improved... I went from a 1.57 avg. to 1.43 avg. With a low of 1.400... I Went from 6# to as much as 9-1/4# my slicks depending on the track...
Doug...
Doug...
ThndrChkn- Posts : 2216
Get a f-ckin' lighter car dude....................
richter69 wrote:As always, any and all suggestions are welcome.
Well, he said "any and all"...
Doug...
he'll go make some photos with my pic in it now.
No need for a lighter car, I'll just up the spray!
Thats some good numbers Greg!!
What starting line procedure are you using now, the same as before?
Bill
Bill
billandlori- Posts : 2081
Nice job. Did you make changes or was the air good that night?
DILLIGASDAVE- Posts : 2262
We did make some changes.
I closed up the gap on the cal-trac bars and loosened the shocks up to a 2 on both sides.
Then a buddy suggested trying a lower pressure in the rear tires, so I went down to 11 lbs. The tire sure looks bad at launch, but it seems to work better.
Greg
Greg
you didnt get any vid did you?
Northwest outlaw- Posts : 962
Was this with your roller spring perches installed?
hotrodmerc- Posts : 46
That was with the roller spring perches.
We found a little more recently, and hit a string of 1.46's.
The front suspension is taking a big beating, and it seems like every time I bring the car home from the track a new bushing is out. This time it's a lower control arm bushing.
Greg
Greg
progress
thats pritty good 60' for a stock body.they are real nose heavy and hard to transfer weight but your doing a good job.good looken car too!
hey greg what springs do you have in the front and rear of your car
rick
rick
63boxtop- Posts : 64
Front springs are stock, 351C w/ air.
Gonna try one more time for the 9's on Sunday out at Texas Motorplex.
Greg
Greg
» long time reader first time registering
» First Time Big Blocker...Long Time Ford Fan
» Took some time off for wifey time !
» SCJ and ported C8 472'' in the works (both finally done)
» it's time for a "good time"
