the pass of the year !!!
+8
Larry Williams
Tony M
61coon
psfracer
dr's wife racing
KY JELLY
12 posters
https://www.youtube.com/watch?v=nMa1gDrKlLc
Re: the pass of the year !!!
That one took balls to stay in it !!
They must be doing better on their track prep last time i was there i loaded mine up after 2 passes. Good thing it is a super nice facility.
KY JELLY- Posts : 1530
KY JELLY wrote:They must be doing better on their track prep last time i was there i loaded mine up after 2 passes. Good thing it is a super nice facility.
what has been said by all the racers the track prep was the best of the best that day ..... there was more grip at the 660' then the starting line .... and that was documented by several big teams using there grip torque meter
The only time I have ever had a issue at holleysprings was when the track temp 130 deg. It's hard to make any where work when it is like that. We always have a good time there.I mostly run their grudge stuff.
Year before last they had some issues there even dragsters were getting loose on the big end . It was bad slick the day i was there. Not knocking the place just telling it like it was , and i have been at some hole in the wall tracks never that slick though even in high temps.
Wow. In addition to the wheel stand, that was an awesome race to.
The shutdown looks short there---is it as short as it looks or is that just an illusion?
Dang, that's bad. I guess 'ol Bruno will be doin this before long.......
61coon- Posts : 1824
Wow !! Good thing that was only a half track pass.
Tony M- Posts : 479
I think it has been managed by some different folks in the past.This makes all the difference in the world.I wouldn't be afraid to go back to it now RandyKY JELLY wrote:Year before last they had some issues there even dragsters were getting loose on the big end . It was bad slick the day i was there. Not knocking the place just telling it like it was , and i have been at some hole in the wall tracks never that slick though even in high temps.
the same thing happened to me this year at GB I went through the 1/4 mile traps on my rear wheels at 160 mph. It wasn't a sticky track that caused it. I had way too much wing on it. It was about 15 degrees its now about 1 degree.
Larry Williams- Posts : 884
well he went thru the traps @ 193 in the 1/8 on drag radials ........... thats a BMF !!!!! ...on the back tires of course
wow 193 is crazy
It is some what of a illusion but the there is a big turn around at the end and the shut down is all pretty steep up hill which helps alot.All in all I would say it is not any worse than US 43 which is not bad at all. I have run mid 5's in my car there with no problems stopping at all.psfracer wrote:Wow. In addition to the wheel stand, that was an awesome race to.
That's bad ass...took balls to stay in that baby!!! He wanted to win!
valleydawg- Posts : 427
somebody needs some hErO nose weight.
Nads of steel................
» baddest pass of the year !!!!
» Will it run a 7 second pass
» Pro comp heads in the final last year semi's this year.
» pass from last night
» Race Results from this weekend
