Differences between stock type block and the a460 block?
Flyinfairlane
Differences between stock type block and the a460 block? Empty Differences between stock type block and the a460 block?
Post  Flyinfairlane October 25th 2012, 9:16 pm
Hey guys. This will be my first time utilizing the a460 block in a build. What are the differences when building the a460? Currently all i have is the block (fresh 4.530 bore), brand new kasse p51 heads as they come from jon set up for solid roller cam and a new trickflow mafia intake. My next purchace will be a rotating assembly (scat 4340 4.5 crank scat rods and i guessing diamond flat top pistons???) It will be 580 ci. What length rod should i run? What bearings should i purchace? I am wanting to make around 900-1000 hp . Also what do i need to do to the heads to achieve this? Porting? Is my valve size ok? Thanks in advance, Brock
Flyinfairlane
Differences between stock type block and the a460 block? Empty Re: Differences between stock type block and the a460 block?
Post  Lem Evans October 25th 2012, 9:38 pm
With the A460 block either rod will work good.....6.7 or 6.8"
Post  Flyinfairlane October 25th 2012, 9:42 pm
Thanks Lem. Are there any advantages or disadvantages from one to the other?
Flyinfairlane
Post  the Coug October 25th 2012, 9:44 pm
personally I like the 6.8 rods keeps the piston up in the bores further
Post  Lem Evans October 25th 2012, 9:45 pm
Not with the longer cyl. walls of the A460 block. .100" rod lenght aint gonna change the ratio much.
Post  richter69 October 25th 2012, 9:48 pm
six demon bag......
Post  Flyinfairlane October 25th 2012, 9:52 pm
Ok thanks guys. By the way Lem, that intake i bought from you looks like a nice piece.
Flyinfairlane
Post  the Coug October 25th 2012, 10:36 pm
that intake is a very nice piece and worth a few extra ponies also
Post  richter69 October 25th 2012, 10:38 pm
Ill have a new one here tomorrow, It will compliment the new QF carb very nice........ Wink
Post  cool40 October 25th 2012, 11:00 pm
richter69 wrote:Ill have a new one here tomorrow, It will compliment the new QF carb very nice........ Wink
baller...............
Post  the Coug October 25th 2012, 11:10 pm
I thought you had one with the Snake mods?
Post  bbf-falcon October 25th 2012, 11:36 pm
It wasn't painted. Laughing
Post  cool40 October 25th 2012, 11:47 pm
violation of the "snake patent".............
