Stock connecting rods hp and rpm limits
+13
64hoov
56Tbird
quick 52
whitefield
17 posters
Page 2 of 2 Previous  1, 2
Stock connecting rods hp and rpm limits - Page 2 Empty Re: Stock connecting rods hp and rpm limits
Post  dfree383 November 1st 2012, 12:07 am
whitefield wrote:
IDT-572 wrote:I have never seen the small dome TRW's just the heavy ones. Question scratch
He said they where heavy and small dome in the same sentence ! ? study scratch !
Hell they will take 7500 all day........
Post  whitefield November 2nd 2012, 11:32 am
Here is what I have decided to do! I am going to put it together to get the car all sorted out and turn it no more than 6000rpm. Then add new rods and lighter pistons Vic. intake Custom solid roller cam and let be.
whitefield
whitefield
Post  64hoov December 16th 2012, 11:28 am
I would run that engine it will last a while until you build something better. I ran a similiar setup in 1964 galaxie but with trw domes with domes machined off stock truck rods and bolts with no miles to 6500 for six or seven years.I had a lot of fun with that motor. Laughing
64hoov
Post  whitefield January 18th 2013, 6:34 pm
64hoov wrote:I would run that engine it will last a while until you build something better. I ran a similiar setup in 1964 galaxie but with trw domes with domes machined off stock truck rods and bolts with no miles to 6500 for six or seven years.I had a lot of fun with that motor. Laughing
Thanks and that is what I plan on doing ! By the way this engine was ran in a 64 Galaxie !
whitefield
whitefield
Post  rmcomprandy January 18th 2013, 7:30 pm
quick 52 wrote:so when do we start the big BANG. why not on april 1. stock rods rule
In 2003 I built an offset ground Ford crank 501 engine for a guy who bought all kinds of parts from people who had engines which blew-up.
It has H-beams on one side and I-beams on the other ... SRP 4032 pistons on one side and Ross 2618 pistons on the other side; (even different material); at least the rings & bearings were new.
A429 heads and Lunati street roller cam with a victor and 950HP carb.
It is a street car, (66 Fairlane), that he takes to the strip about 4 times a summer for fun. I sent his lifters to get rebuilt for the second time this winter. He DRIVES this car and has almost 20,000 road miles, too.
Changes his oil and filter whenever it looks a LITTLE dirty and he is constantly tinkering with the rest of the car; (in 2010 he put in a 700R4 with a TCI valve body using a Powerglide kit so, he had an overdrive for highway cruises).
As long as the specific parts are not overstressed, mismatched doesn't mean a thing.
Post  738drvr January 18th 2013, 7:36 pm
Mike, Glenn took meticulous care of all his stuff. You should see his garage. If he says he didn't rev it above 6k, it never saw 6100. He told me he ran that engine for 3 seasons(IIRC). The last owner couldn't have run it for very long. I think you could run it for a long time at 6k.
Have fun.
Post  whitefield January 25th 2013, 4:55 pm
738drvr wrote:Mike, Glenn took meticulous care of all his stuff. You should see his garage. If he says he didn't rev it above 6k, it never saw 6100. He told me he ran that engine for 3 seasons(IIRC). The last owner couldn't have run it for very long. I think you could run it for a long time at 6k.
Have fun.
Frank , thanks for the incouragement ! I have plans to get started back on it this next week , and hope to have it running in the next six weeks. Glen is a well spoken gentelman and a very stand up person!
whitefield
whitefield
Stock connecting rods hp and rpm limits - Page 2 Empty My experience from yesterday
Post  460Dave February 3rd 2013, 9:48 am
85 T-bird, 3,000 lb, 315 radial, 4.11 rear, glide w/brake. P-51 headed 466, mech roller, stock crank, stock football headed rods w/ ARP 2000 bolts. Best ET 10.09 @ 134.67 mph. 25 passes. Yesterday, 1st pass ran a 10.67 @ 126. It was knocking at the top end. Drove it back to the pits with everyone looking at me like "Dude! WTF!" Tore it down last night and found one rod bent like an "S", bearing beat out of it. Rod didn't break, but it sure wasn't straight. The rod was still bolted up, but the little end was pushed hard against the piston (sideways). The piston had some scuffs on it, but still looks "together"
That is the only piston I pulled (it was midnight) but with the engine on the stand and upside down, the rest of the rods look straight.
I typically left the line at 4000 rpm, shifted at 6500 and had a 6700 limit chip. Rods were "race prepped" as good as you can possible prep a stock rod. Rotating assembly was balanced and pistons were the TRW light weight forged flat tops. 678 gram
oh, additional find. When I unbolted the oil pump, I found one ear broken completely (Stock, Melling pump)
BTW..... looking for parts
460Dave
Post  69F100 February 3rd 2013, 11:03 am
my 460 has stock crank, rods with the stock rod bolts with cheap speed pro flat top on the last freshen last year never balanced it.I have ran it 3 years turning it 6500 with no problem from them.It will be coming out soon and replaced with the 552 and it will be pulled apart and checked again then.The truck is 3165# runs 6.70's in the 1/8 at 100mph on foot brake.
Post  whitefield February 3rd 2013, 4:23 pm
69F100 wrote:my 460 has stock crank, rods with the stock rod bolts with cheap speed pro flat top on the last freshen last year never balanced it.I have ran it 3 years turning it 6500 with no problem from them.It will be coming out soon and replaced with the 552 and it will be pulled apart and checked again then.The truck is 3165# runs 6.70's in the 1/8 at 100mph on foot brake.
What is the quick run down on your truck build gear ratio stall tire size ect ?
whitefield
whitefield
Post  Barney February 3rd 2013, 4:47 pm
I ran in th 8s with stock rods and a ton of spray shifting at 6800 for 3 seasons.
Barney
Barney
