533 Dyno Results
Re: 533 Dyno Results
Wow it was lean, what fuel was used? Good numbers..........
Do you mind re-posting your build, I can't find it?
IDT-572 wrote:Wow it was lean, what fuel was used? Good numbers..........
Looks like the high speed air bleed could stand to be smaller.....went lean at higher rpm.
P-51 heads???
70FB- BBF CONTRIBUTOR
We had some valve train problems around 6800 on up. Notice the power dropped off then came back up. Went with T D shaft mount but didn't dyno it afterwards. Was trying to make it to the last truck pull of the season ( Nov 3rd ) but due to work schedule won't make it. Hopefully get it back on the pump in the spring for some tuning. Yes, out of the box P51s with titanium retainers. Cut the heads some to get comp up to around 14.5. Ran it on VP C114. I'll post the build after the power comes back on or after I get back from Atlanta, whichever comes first. LOL. The battery in this laptop is getting low and I want to keep some reserve to check the weather.
posford- Posts : 90
» Dyno results: A headed 557 on 91 octane pump gas. DYNO UPDATE page 6
» dyno next week any hp guess's ///rod picture damage and dyno sheet added
» Going to the dyno..
» Dyno overlay
» TRYING to shut my chevy friends
» Dyno overlay
