valve covers
LivermoreDave
motorhead
valve covers
I have a set of tall valve covers and I need to punch some breather holes in them. Any tips on this and should they have baffles? Any help would be great.
motorhead- Posts : 75
Re: valve covers
Yes a tip if I may? Locate the breather device you intend to install before "punching" the holes.
Dave.
Dave.
LivermoreDave- Posts : 972
valve covers
I have guide plates and roller rockers so I can't use my old valve covers, but should the breather hole be located in the same place as the factory covers over the stamped rockers? Just want to make sure I get this right the first time.
Re: valve covers
I think the "stock" location would be good. An important thought is, not to place the opening over or in-line with a rocker arm. Two concerns of mine would be dynamic rocker arm interference and oil being directed toward the opening. Of course, check for any interference of parts you plan to cover. If you did want to use the stock type valve covers, you could add gaskets to raise the valve cover.
Dave.
Dave.
valve covers
Thanks a lot Dave, I had not even thought of that little trick and that seems to be a good solution too. I did a mock up yesterday and it seemed as if I had enough clearence with the stock valve covers, but I could add the extra gaskets just in case; like when every thing is rotating.
Re: valve covers
Not sure what you're doing, but you can easily stack gaskets and elongate holes to move the covers around. I managed to get a set of 429CJ/SCJ covers on a SCJA head by doing that. As a point of interest, those valve covers are more forgiving than the stockers - different angles coming off the flange.
John I.- BBF CONTRIBUTOR
Re: valve covers
They make a spacer just for this.
Re: valve covers
motorhead wrote:Thanks a lot Dave, I had not even thought of that little trick and that seems to be a good solution too. I did a mock up yesterday and it seemed as if I had enough clearence with the stock valve covers, but I could add the extra gaskets just in case; like when every thing is rotating.
I bought a set of tall aluminum valve covers for my roller reckers but couldn't use them, my power brake booster was too big. Stacked 3 gaskets, what a mess, hard to line up and could not stop the leaks. Bought a set of valve cover spacers at the Columbus Spring Swap, very good investment even at $120. I have also seen them on e-bay.
GT300TD- BBF CONTRIBUTOR
Re: valve covers
Jegs has these http://www.jegs.com/i/B-B/128/63930/10002/-1?parentProductId=747514 and I know Blue Thunder makes them also
Mike R- Posts : 1381
Re: valve covers
Mine are 1/2 " thick.
» valve cover studs for aluminum valve covers
» Sheetmetal valve covers
» 429 M/T valve covers
» valve covers?
» WTB: Mickey Thompson Valve Covers
» valve covers?
