Foxbody drive shaft w/C4
I need to know the length of a Foxbody DS in a BBF fox w/engine plate and C4 tranny and 9" housing. If someone knows the length from joint/joint then I would know what to look for at the swap. Any help would be appreciated.Thx
Re: Foxbody drive shaft w/C4
bbf-falcon wrote:I need to know the length of a Foxbody DS in a BBF fox w/engine plate and C4 tranny and 9" housing. If someone knows the length from joint/joint then I would know what to look for at the swap. Any help would be appreciated.Thx
Are you running the cross member for the trans and if so is it in the stock location ?
What Isthe Lengeth of the yoke on the rear ?
whitefield- Posts : 2244
Check with Damon, he had a c-4 in his car once upon a time. He may even have still his old driveshaft. If you ain't got his number, call me and I'll give it to you. ---RED
61coon- Posts : 1824
Hey Rick I had the aluminum driveshaft from Ford in mine with a C-4 and 9 inch. Driveshaft measured 45 1/2 inches center to center. Now I wasn't using an engine plate. I have a QA1 tubular K member. Double hump crossmember from Ford without any mods.
514Fox87- Posts : 436
61coon wrote:Check with Damon, he had a c-4 in his car once upon a time. He may even have still his old driveshaft. If you ain't got his number, call me and I'll give it to you. ---RED
Thx Red,I have his # and email address. I will get in touch w/him.
Thx Melvin,that will help a bunch.
Driveshaft
I be got a brand new aluminum shaft from I think dynotech...
Wit billet c4 yoke. Wit big u joints..
Was for 87 wit 477 and c4...was using 1/4 motor plate and .100 steel midplate...
Not 100% sure but believe center to center was Ike 35"... Have to double check it interested.
Can send pics if u would like .
Jason
402-416-8988
Jason
402-416-8988
bbfdragster- Posts : 121
Sounds awful short.
Shaft length
It maybe ... I wanted better weight transfer n got rid of stock location mounts...I had front of motor inline wit shock towers n bolted plate to tower... Made it super easy to put motor in... Had a turnbuckle bolted to side of block to prevent twist.... Motor was only 750 hp.. But worked awesome..
» Drive shaft
» WTB drive shaft for 1989 fox
» FNG from lockbune, Ohio
» 58" Drive shaft
» New Driveshaft
» 58" Drive shaft
» New Driveshaft
