Porting TFS A heads and intake
I have an a newstyle tfs cast single intake and lightly cleaned up 2.35 tfs A heads.
Would it benifit any by porting on the heads and or intake if everything else in my combination remained the same?
Heres my build...
https://www.429-460.com/t14610-dyno-results-a-headed-557-on-91-octane-pump-gas
Btw...Happy thanksgiving!
Heres my build...
dirt_worker- Posts : 535
Re: Porting TFS A heads and intake
Definetly some power to be had.
my engine guys flow bench is known to be conservative and these heads flowed 400 and 300 on a 4.400 bore (we used that sleeve since it was the closest he had to my engines bore size)
How much help does the tfs intake usually need and what kinda flow are most of you guys getting from the a heads?
My one set is going 465 @ .800 with a 45 deg valve job and a 2.35 ss valve they can get over 500 with alot of work and a serious race valve job and larger valve.
