SCJ HEADS.....
lghting94
Northwest outlaw
J R
SCJ HEADS.....
We have them on the motor now an they have had a 3-angel valve job done to them.A pic of one of the heads.
we would like to know if we could do some more work to them.
J R- Posts : 82
Re: SCJ HEADS.....
Do i see that right you have a d2oe ab , d2ve head there i can see in the pic that good?
Northwest outlaw- Posts : 962
Re: SCJ HEADS.....
if that code number on the second exhaust port reads as it looks D2OE-AB those are PI heads the CJ heads Code is DOOE-R and yes either way they can be made to flow quite well....if in the right hands... you can get lots more power if you throw that Edelbrick carb in the trash also and get a holley.... or Quick fuel...
the Coug- Posts : 3055
Re: SCJ HEADS.....
D20E-ABNorthwest outlaw wrote:Do i see that right you have a d2oe ab , d2ve head there i can see in the pic that good?
J R- Posts : 82
Re: SCJ HEADS.....
What is a PI head,the Coug wrote:if that code number on the second exhaust port reads as it looks D2OE-AB those are PI heads the CJ heads Code is DOOE-R and yes either way they can be made to flow quite well....if in the right hands... you can get lots more power if you throw that Edelbrick carb in the trash also and get a holley.... or Quick fuel...
this is the carb
J R- Posts : 82
Re: SCJ HEADS.....
a PI head came on Police interceptor engines they came in Police cars.... they have slightly smaller intake volume and usually have a 2.19 intake valve compared to the CJ head which had 2.250 intake I think they both came with 1.76 exhaust valves unless it was a SPEC head and then it could have came any way possible. Ford did a bunch of experimenting with heads and they were marked SPEC couple have bigger intake runners bigger valves or different exhaust.... no one knows....
In essence they are good heads and can be made to flow good, just have to be put in the right hands to work, do not just grind away that will ruine them faster than anything....
Re: SCJ HEADS.....
damn thats what kind motor this is its been bored 40 over,an we put a very high cam in it we got from my granddads friend.so who's hands do they have to go to.the Coug wrote:a PI head came on Police interceptor engines they came in Police cars.... they have slightly smaller intake volume and usually have a 2.19 intake valve compared to the CJ head which had 2.250 intake I think they both came with 1.76 exhaust valves unless it was a SPEC head and then it could have came any way possible. Ford did a bunch of experimenting with heads and they were marked SPEC couple have bigger intake runners bigger valves or different exhaust.... no one knows....
J R- Posts : 82
Re: SCJ HEADS.....
My PI heads came with 2.19/1.73 valves as did the other set I know of.
lghting94- Posts : 762
Re: SCJ HEADS.....
if you were wanting to send them out Scotty at reincarnation he is the Mad Porter on here...PM him and see what he can do for you.....
Re: SCJ HEADS.....
Scotty is a very competent iron or aluminum head porter, as is Bret Powell. Both can be reached here on this board.the Coug wrote:if you were wanting to send them out Scotty at reincarnation he is the Mad Porter on here...PM him and see what he can do for you.....
schmitty- Posts : 4538
Re: SCJ HEADS.....
.lol for the carb
Last edited by 73f100shortbox557SCJ on October 8th 2009, 9:27 pm; edited 1 time in total
73f100shortbox557SCJ- Posts : 93
Re: SCJ HEADS.....
One big difference between SCJ and PI heads from a performance standpoint is the chamber size. Your PI heads will have a much larger chamber then SCJ heads - so you won't have the compression with the PI heads you would with SCJ heads unless they've been milled.
Brian_Eyler- Posts : 32
Re: SCJ HEADS.....
Brian_Eyler wrote:One big difference between SCJ and PI heads from a performance standpoint is the chamber size. Your PI heads will have a much larger chamber then SCJ heads - so you won't have the compression with the PI heads you would with SCJ heads unless they've been milled.
Brian I forgot about the chamber volume but either way they will make him some good performance heads....
Re: SCJ HEADS.....
Whats milledBrian_Eyler wrote:One big difference between SCJ and PI heads from a performance standpoint is the chamber size. Your PI heads will have a much larger chamber then SCJ heads - so you won't have the compression with the PI heads you would with SCJ heads unless they've been milled.
J R- Posts : 82
Re: SCJ HEADS.....
milled is machining the face surface down to decrease the chamber volume (or make it true)
IIRC the PI head has a different/better exhaust port than the CJ head
Diggindeeper- Posts : 800
Re: SCJ HEADS.....
Yes the PI's do have a little better exhaust port than the CJ/SCJ's... They also have a nominal 88cc combustion chamber vs. 72cc for the CJ/SCJ... I had 2 sets of PI heads that were date coded SPEC and 1 ste of SCJ' that were date coded the same... On the PI heads, one set had CJ intake ports and the std 2.19/1.72 valves, and the other set had 76cc chambers with CJ intake and exhaust valves but had the PI ports... I don't know what tha SCJ's had different under the SPEC date code, 'cause they were already too big to begin with... X2 on talking with Scotty aka The Mad Porter about having your heads tweaked... He's undoubtedly, the iron head master of the BBF...
Doug...
Doug...
ThndrChkn- Posts : 2216
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» A429 Heads VS Dove-c Heads
