water pump belt adjustment
water pump belt adjustment Empty water pump belt adjustment
Post  tconnection December 9th 2012, 1:21 am
Im wanting to run a mechanical water pump and belt.
What would i have to use to adjust the belt tight? What bracket? Plus the engine is on a motor plate.
tconnection
water pump belt adjustment Empty Re: water pump belt adjustment
Post  66prostreetfairlane December 9th 2012, 8:55 am
Why not run the belt from the crank to water pump to alternator with the alternator having adjustment. Being that your using a plate you may need to make spacers for alignment.
66prostreetfairlane
66prostreetfairlane
https://www.reiautomationsquad.com/
Post  tconnection December 10th 2012, 12:43 am
Sound good.I gotta see if i got a bracket around here.
tconnection
Post  69F100 December 10th 2012, 2:05 am
you could find a a/c belt tengener off a mid to late 70s model ford truck if you are using a v-belt and make a bracket to hold it and still have it adjustable souldnt be hard to find st s local junk yard
Post  tconnection December 13th 2012, 11:20 pm
Ok thanks.
tconnection
