anyone use the March of CVF tall alternator pulley?
anyone use the March of CVF tall alternator pulley? Empty anyone use the March of CVF tall alternator pulley?
Post  mtacqua December 21st 2012, 10:08 pm
http://www.summitracing.com/parts/mch-147/overview/make/ford
http://www.ebay.com/itm/Big-Block-Ford-Alternator-Pulley-429-460-Billet-Aluminum-1V-Tall-Alt-BBF-V-Belt-/110740925670
I need a taller pulley, was going to get a one made (not cheap). These might work, I need the measurement to the from the back to the center of the V. Also, how much material is on the mounting face? I might still be cheaper/faster to turn one of these down.
mtacqua
mtacqua
anyone use the March of CVF tall alternator pulley? Empty Re: anyone use the March of CVF tall alternator pulley?
Post  quick 52 December 21st 2012, 10:34 pm
mtacqua wrote:http://www.summitracing.com/parts/mch-147/overview/make/ford
most alternator can take 15,000 rpm so figure your crank pulley to alternator pulley. most gm and ford pulley will work on either alternator.
quick 52
Post  mtacqua December 21st 2012, 11:35 pm
not a bigger diameter, taller. the alternator is to close to the block (new bracket and already made some other changes not knowing I had this issue). Easy fix would be a pulley the stuck out further to line the belts up.
mtacqua
mtacqua
Post  DanH December 22nd 2012, 12:27 am
mtacqua wrote:not a bigger diameter, taller. the alternator is to close to the block (new bracket and already made some other changes not knowing I had this issue). Easy fix would be a pulley the stuck out further to line the belts up.
just and the distance to a stock pulley that needs to be moved out to the custom made pulley
OR do what Ford did and most others including me ..... ADD a spacer . btw , spacer doesnt move the pulley out on shaft but the whole ALT.out
DanH
Post  mtacqua December 22nd 2012, 9:50 am
yeah probably going to get a pulley made, just checking to see if this pulley was moved out as far as I needed. I am going to use a GZ pulley on the crank so I can go inside or out the vacuum pump pulley slot.
mtacqua
mtacqua
