How much power has been made
56Tbird
Mahoney3105
Anybody build a max effort BBF using kassie A441 hemi heads with a big inch motor. what do these heads flow from John kassie ?
Mahoney3105- Posts : 28
Re: How much power has been made
The big inch stuff is making well over 2.2 hp per CID NA from what I've seen.
Mahoney3105 wrote:Anybody build a max effort BBF using kassie A441 hemi heads with a big inch motor. what do these heads flow from John kassie ?
Let's try to get it right. It's Jon Kaase.
Be advised that the A-441 heads are like a generation older head and Jon doesn't use them anymore in his big mountain motors. He uses the B-441 heads (also known as the Roberts Design heads). It's a physically bigger and taller head than the A-441. Carroll Carter at C & C Motorsports in Manasas, VA is the supplier/vendor of both of the currently available A-441 and B-441 heads. In the B-441 family, there are three versions available.
Also, the 2.2 Hp per CID that Dave mentioned comes from the B-441 heads, not the A-441 heads.
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Dang,I thought it was Cosby.....Bill Cosby At least that's what I heard once at TexasRoadhouse
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Dang,I thought it was Cosby.....Bill Cosby At least that's what I heard once at TexasRoadhouse
Then it has to be true, because we all know if it's said at the TR, it's gospel truth, because there ain't no BS'n there at all.
schmitty- Posts : 4538
I saw it posted on the internet. And everything you read on the internet is truth......
kjett- Posts : 1169
No, no, no. Cosby had the twin Paxtons on a Cobra that Shelby built.
cletus66- Posts : 865
AND you believed the check was in the mail alsocletus66 wrote:56Tbird wrote:Dang,I thought it was Cosby.....Bill Cosby At least that's what I heard once at TexasRoadhouse
dave d- Posts : 809
» Sealed Power HFT Ford Lifters Made in Mexico HT-900 72 Bucks a Set (16)
» made it over
» TFS tunnel ram
» made in the USA ....
» We made it to Windy
» made it over
» TFS tunnel ram
