Speak plug recommendation for alky
Happy New Year!
I just finished converting my car to methanol. Set up is:
514ci, 12.5 compression, PI heads, QF950A, rear mount fuel cell w/ Magnafuel Prostar pump, -10 to MF regulator, -8 to fuel log, -8 to carb. Vacuum pump.
What would be a recommended plug, prefer NGK?
Brian Cagle
Brian Cagle
PanaVet- Posts : 47
Re: Speak plug recommendation for alky
alky does not need a specific plug, run the same as if it was gas.
watch the seals on that mf pump w alky, been there done that
I like ngk-8 or 9.
AlkyPinto wrote:Autolite Racing 3910
It'd depend on the dome...with the projected tip of the 3910.......it is the correct heat range for sure
I do have to index the 3910 plugs in my 14:1 motor.
So as Lem stated be sure to check that! Might be
okay tho with just 12:1???
» 521 SR71 spark plug recommendation
» Spark plug recommendation and jetting
» spark plug recommendation for TFS Streets?
» SPARK PLUG RECOMMENDATION FOR SCJ-A ALUMINUM HEADS
» Alky carb vs. Alky injection
