hydro Steering
hydro Steering Empty hydro Steering
Post  79Puller January 7th 2013, 8:36 pm
Has anyone ever just used a electirc Hydro steering box ran into the stock steering box for a puller. If so how did this work and anything special needed to finish this.
79Puller
hydro Steering Empty Re: hydro Steering
Post  HorsinAround January 7th 2013, 8:46 pm
If you are referring to an 12vdc hydraulic pump, then yes, I have done it and it worked ok until I got up over 1500 lbs on the weight bar. Then its a good idea to replace the stock gear box with full hydro steering.
http://www.frontpagefab.com
Post  72puller January 7th 2013, 9:22 pm
I've been running mine plumbed to the box for 5 years with zero problems. Mount your switch for the pump within easy reach so you can turn it on and off when driving around before and after you pull to save your battery.
72puller
72puller
Post  79Puller January 8th 2013, 11:35 am
Thanks guys, I hang a little over 1k on the front so this should work good.
79Puller
Post  HorsinAround January 8th 2013, 11:42 am
Just make sure you set the pump pressure to the maximum pressure recommended for the stock gear box as the pump can put out alot more pressure than a stock gear box can handle. Also, don't be surprised if you have difficulty turning the wheel when stopped.
Alan
Post  79Puller January 8th 2013, 12:52 pm
Alan, How do you know how much pressure the stock box will take ? Is there settings on the pump ? Was going to order the pump within the next day or two.
79Puller
Post  HorsinAround January 8th 2013, 1:21 pm
You might want to ask these questions over on the Reddog forum. Those guys are dedicated to truck pulling.
If memory serves I seem to remember 1100-1200 as the max recommended on the oem gear box but that was for for my truck and may be different for yours.
Post  72puller January 8th 2013, 9:12 pm
This is the unit I'm using on my truck. I never made any pressure adjustments.
http://www.grainger.com/Grainger/HALDEX-BARNES-Basic-Power-Unit-4NE17?Pid=search
72puller
72puller
Post  79Puller January 8th 2013, 9:28 pm
Thats what I was looking at...thanks
79Puller
Post  79Puller January 8th 2013, 10:08 pm
I was wrong I was looking at model #1261009 can someone tell me the difference, between this and model #1560049.
79Puller
Post  HorsinAround January 9th 2013, 10:53 am
This is the one you need, and its cheaper than Grainger.
http://www.northerntool.com/shop/tools/product_200329758_200329758
Post  79Puller January 9th 2013, 12:14 pm
Great,,,thanks again
79Puller
Post  kjett January 10th 2013, 4:21 pm
HorsinAround wrote:This is the one you need, and its cheaper than Grainger.
That's the pump I run on my full hyro steering setup. Works great but sucks up a TON of electricity to run it for very long.
kjett
kjett
Post  HorsinAround January 11th 2013, 9:36 am
Any of them suck alot of electricity! I actually bought one from a company that set the pressure and everything for me and it wasn't a haldex unit, but it was still the highest single power draw on my truck.
That said, I ran 3 1000 cca deep cycle batteries from Napa and no alternator and I could easily get 3 runs before recharging if I had to. Generaly though, I charged after every run. Dont know if it made any difference, but I completely rewired my truck and took out all the original wiring and dash, so there wasn't any "extras" drawing power.
