BBF Power Glide - SOLD
frank13
soupbean
I have a fresh 0 passes glide rebuilt by Neal Racing Transmissions. Stock case. 1.76 gear. 7 clutch high gear. Billet servo. Turbo input shaft. JW Ultra bell housing. TCI sheild. Pro brake. Deep aluminum pan. Ready to go. $1400. Will trade up or down. Need data logger, 96-98 wing, 6" cowl hood, Black Welds 15x11 double bead locks and matching fronts, Strange calipers, aluminum carb tool tray, adjustable lower spring brackets for 8.8 stock location, 26 x 4.5 front runners, -12 an stuff, vacuum pump, Q16 fuel, midget clown strippers, flat crank pulley, two headed chickens, quick disconnecting chute for sn95, beer.
soupbean- Posts : 637
Re: BBF Power Glide - SOLD
hit barney up about the midget clown strippers........
I think I have a lead on the midget clown strippers but I left out virgin goats if you know anyone with some looking for a glide. Up to 1/2" ports will be fine...
And will throw in a JW "wheel"
soupbean wrote:And will throw in a JW "wheel"
Man if I wasn't in the middle of my 552 build I would buy it maybe I will hit the lotto and can buy it well that want happen got the play it 1st
Do you still have it? Do you have a converter also ? Reverse VB? Trans brake?
I got a.brand new super comp PA with 10 in.nitrous converter.but I went ahead ditched the 408 idea. Going 521 or 545 could you use a trans like that? Comes with JW bell.for sbf. Trans brake too
2fox- Posts : 275
2fox wrote:Do you still have it? Do you have a converter also ? Reverse VB? Trans brake?
No converter. Pro trans brake. I have no need for a sbf trans. Thanks
any need for a 8.8 or 9 inch rear?
8.8 31 spline eaton posi, Alloy usa axles, trick flow rear cover. 3.73 gears 5 bolt
9 inch Detroit locker, 3.89 gear 31 spline , drum backing plate 4 bolt alum pinion support.
Thanks for the offer but no. I have listed everything I think I need. I really should keep it as a back up and something tells me I will regret getting rid of it but have other things I want right now such as a RacePak.
Is it the same length as a stock glide? I have two gildes with a pro brake but I have a midplate I use.
Soupbean, you have a pm.
maverick- BBF CONTRIBUTOR
Moodyblues wrote:Is it the same length as a stock glide? I have two gildes with a pro brake but I have a midplate I use.
Yes
maverick wrote:Soupbean, you have a pm.
I have no pm
What the....? Lemme try again.
JDHATHOME wrote:You should have a pm
Returned pm. Thanks
» Broke forward drum after mig welding the peanut holes solid.
» JW POWER GLIDE
» help! power glide
» power glide?
» power glide
» JW POWER GLIDE
» help! power glide
» power glide?
» power glide
