Eccentric mounting ?
Wheelie58
OldRed70
Just got the 1 piece fuel pump eccentric in from Lem . I know I read it somewhere but can't find it . My question is my old 2 piece has a nipple bent out to fit in the cam to hold it from turning and the New one I got doesn't how do you mount it to the cam to keep it from spinning around the bolt . Any input would be appreciated
Jimmy
Jimmy
OldRed70- Posts : 155
Re: Eccentric mounting ?
Jimmy
I am just running off memory, but I believe there is a hole in your solid eccentric that aligns with the cam pin.
It seems like the cam pin should protrude past the face of the top sprocket and engage the hole, but not stick out past the eccentric. The cam bolt washer then covers a portion of the pin.
Maybe that helps???
Keith
Maybe that helps???
Keith
The older 1 piece for the 385 engine had no hole and relied entirely upon the cam bolt clamping to keep it from turning.
Randy is correct, as usual. But if it worries you, you can pin the eccentric to the cam gear.
Wheelie58 wrote:When I grow up, I want to be like Randy!
What really irritates me sometimes is the little (simple things) like that that I forget as I get older.I find myself going back to my engine manuals for torque spec's etc. Really sucks getting older huh Keith.
Thanks Keith , Randy , & Lem . I will get it installed over the weekend.
just had that same thing happen to me last week end when i put my 460 back together its a 69 460
has no notch like newer style i just put it on and used lock tight if i have a problem next time i'll pin it
74f100- Posts : 28
That's what I am gonna do . Been debating about it for a few Days
» eccentric help
» Fuel Pump Eccentric ...
» Two-Piece Fuel Pump Eccentric
» Need a new fuel pump eccentric and bolt
» Need a 2 piece fuel pump eccentric and cam bolt/washer for 351W.
