header studs
header studs Empty header studs
Post  514Fox87 January 19th 2013, 10:03 am
Do you guys use header studs or just bolts? A429 heads in a foxbody with Kooks headers. Which stud kit would work best?
514Fox87
514Fox87
header studs Empty Re: header studs
Post  dfree383 January 19th 2013, 10:25 am
studs can be a PITA on a Fox body, sometimes you need to slide the tubes inplace and the studs can make that hard.
are your headers Indvidual tube or single flange for all 4 tubes?
Post  514Fox87 January 19th 2013, 10:45 am
They r individual tube. Just seems I'm pulling them off so often for one reason or another don't want to mess up the heads.
514Fox87
514Fox87
Post  dfree383 January 19th 2013, 10:53 am
They are a good idea, but like I've said, you may not be able to use them on all tubes in a fox.
Post  514Fox87 January 19th 2013, 10:59 am
Thanks Dave. Think I will save my money because I do have to slide them like u said, but the Kooks aren't bad to put on.
514Fox87
514Fox87
